icon
Discussion in 'Suspension' started by RIDDICK3, Nov 14, 2012.
  1. Nov 14, 2012 at 5:53 PM
    RIDDICK3
    RIDDICK3 [OP] nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    got some icon coilovers and am wondering how much thread should be showing to get full 3 iches and will the ride suck
  2. Nov 14, 2012 at 5:56 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Cranked all the way up the ride might be harsh, especially at slow speeds. Hopefully someone running icons will pop in.
    My kings got a bit bumpier after cranking em up some more.
  3. Nov 14, 2012 at 6:04 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I have about 10 threads showing on my danohoes (ICON) and have 2.5 inches of lift....
  4. Nov 14, 2012 at 6:05 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    At 3" you will be at the farthest limit of the coilover assuming they are the extended travel units. You will have very little droop travel, and when your shocks top out it will feel like your front end is going to rip apart. Other than that, it will ride the same as 1" lift.
  5. Nov 14, 2012 at 6:25 PM
    RIDDICK3
    Stefan
    Orem, Utah
    i just got them dont know if there extended travel or not but when i got then one was set 2 3/4 from top to shock and the other 1 3/4 here they are
  6. Nov 14, 2012 at 6:50 PM
    BulletToothTony
    I would crank those down a lot. Measure your starting height then add preload as needed to reach your 3 inch goal. Also do you have top plates for the coilovers?
  7. Nov 14, 2012 at 6:55 PM
    RIDDICK3
    Stefan
    Orem, Utah
    no I am going to order some do I adjust them on the truck or do I have to take them off every time
  8. Nov 14, 2012 at 7:17 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    I was told by DSM to have them in a spring compressor in order to adjust them. I am in the same boat with not knowing how much preload to put on my used set that I just picked up and rebuilt...
    Are you running a bumper or winch?
  9. Nov 14, 2012 at 7:23 PM
    BulletToothTony
    I adjusted mine on the truck using the spammer wrench and cheater pipe it's actually fairly easy. With so much preload already on the coilovers your probably gonna have a hell of a time getting them on too
  10. Nov 14, 2012 at 7:25 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Speaking to Icon you can adjust these on the truck and you do not need a spring compressor.
    But those are NOT gonna fit a 2nd Gen Tacoma. If you are going to keep those shocks (and I don't know if you can just put a top plate on those and make them work) you are going to need to get the 2 piece spacers for the bottom
    And yes you need to lower those.
  11. Nov 14, 2012 at 7:30 PM
    BulletToothTony
    ^^^ :confused:
    Yes those will work for second gens he just needs the top plate. I sent one of mine to icon to get it fixed before I put them on my truck. But you are right about needing the spacers that go on the bottom of the coilover...
  12. Nov 14, 2012 at 7:33 PM
    RIDDICK3
    Stefan
    Orem, Utah
    what spacer you talking about? but ya i talked to icon gonna order top plates for them soon
  13. Nov 14, 2012 at 7:35 PM
    BulletToothTony
    At the bottom of the coilovers where the LCA bolt goes through there are little spacers that go on each side to keep it lined up. When u order the top plates just tell them you need a pair.
  14. Nov 14, 2012 at 7:36 PM
    Mitch
    Mitch
    Spokane, WA
    Call Icon back and ask for the Lower Control Arm spacers. Its long spacer (front) and a short spacer (rear)
  15. Nov 14, 2012 at 7:36 PM
    RIDDICK3
    Stefan
    Orem, Utah
    like they go inside that ball joint on the bottom
  16. Nov 14, 2012 at 7:37 PM
    Mitch
    Mitch
    Spokane, WA
    My bad. Sorry mine came new and it had the top plate on them so I don't know what they look like without the plate
  17. Nov 14, 2012 at 7:57 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    I have the Icon Extended travel with resis and I love them. They're a huge improvement in ride comfort and performance. Mine are cranked up pretty well but based on measurements front of frame and back they're adjusted where I want them. I would say I have almost a full three inches of lift. It's also going to depend on your personal preference and existing armor gear and use for your truck. Overall I'd def make the purchase again. Best of luck
  18. Nov 14, 2012 at 8:11 PM
    RIDDICK3
    Stefan
    Orem, Utah
    how many threads are showing on yours?
  19. Nov 14, 2012 at 8:21 PM
    Mitch
    Mitch
    Spokane, WA
    I have about 1.25" showing I believe. Ill check tomorrow. And I have not adjusted anything. Just threw them on
  20. Nov 14, 2012 at 8:25 PM
    RIDDICK3
    Stefan
    Orem, Utah
    those that are running these what are you hub to fender and how many threads or iches showing
