Icons....need help. Broke another clamp...and another
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Mar 10, 2017.
  1. Mar 24, 2017 at 12:51 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Take a pic of the edges of the bands. Looks to be they are catching a edge and maybe when the cylinder heat up and expend applies more pressure on the clamps. Aluminum thermal expansion is twice vs steel. I would either grid down the back side where the strap goes around or apply some type of padding that will give before the band.
    nevadabugle[OP] likes this.
  2. Mar 24, 2017 at 12:57 PM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Good idea. Thanks. After replacing 4 of them something has to be changed. I like the idea of padding. I'll have to see if I can find some thin rubber.
