Icons or fox 2.0" coil overs? with Total Chaos UCA.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco me elmo, Jun 17, 2011.
  1. Jun 17, 2011 at 9:24 PM
    Taco me elmo
    Taco me elmo [OP] Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
  2. Jun 17, 2011 at 9:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  3. Jun 17, 2011 at 9:33 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Those are 2 inches only as well, I am looking for a mid travel kit with a 0-3 inch lift.
    Also SAW are Icons in different clothing with lesser lift option.
  4. Jun 17, 2011 at 9:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    SAWs are 0-3". Icon does not make SwayAway COs.
  5. Jun 17, 2011 at 9:40 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
  6. Jun 17, 2011 at 9:48 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Elbach springs set your 5100's @0 and save yourself some money's
  7. Jun 17, 2011 at 9:51 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I want a solid mid travel front end and plan to use an add a leaf from icon in rear and new upper control arms and coil overs up front for a solid lift and all terrain ride quality.
    I was happy with my 5100 because they only cost me $200.. but they ride like $200 shocks anymore.
    I know a cheap alternative is add the Old man emu springs to the 5100 for more lift but I would still be on stock components and that's what I want to upgrade from.
  8. Jun 17, 2011 at 9:57 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I love my icons! I believe u can get em with resi also. Had mine for three years and I beat on mine :D just added icons rear resi with deaver j59 pack, can't wait to test it out.
  9. Jun 17, 2011 at 9:59 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Contact I believe DSM and have them valve a set kings for ya. Should be around same $ as for icon....
  10. Jun 17, 2011 at 10:03 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    if you want to get the full use out of a uni ball UCA then you have to run an extended length coilover to get the extra inch of down travel and have a true "mid" travel suspension
    icon is the only company i know of that makes an ext length coilover
    get icons... i've had 2 sets of their CO's and could not be happier
  11. Jun 17, 2011 at 10:04 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    x2
  12. Jun 18, 2011 at 5:33 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
  13. Jun 18, 2011 at 5:56 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    x3 on icons
  14. Jun 18, 2011 at 5:57 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Icon uses a digressive valving Set up while sway a way uses a progressive valving set up.
    In reality kings, saw/camburgs, fox, and icon/Donahoe are all great products. Just pick a color.
  15. Jun 18, 2011 at 1:01 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Talked with dan from wheelers before and he said SAW makes an ext travel coilover, and the camburg coilover bridges the gap between stock travel and extended travel.
  16. Jun 18, 2011 at 1:08 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Icon's FTW!!
  17. Jun 18, 2011 at 9:39 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I am going to go Icons, The 1 inch longer travel ones are on back order but the normal ones are available.
    Going to go with Total Chaos Uppers with them, So it wont really matter because I dont plan to over extend them.
    Going to talk to ORW Monday about the stuff.
    If all goes well I should have it all installed by next monday.
    Speed Freak Jason will hook it up with the install.
  18. Jun 18, 2011 at 9:46 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Dude if your getting the UCA's wait to get the extended travel shocks. You wont over extend them if you get UCA's. If you dont you will wish you did. If you dont get the extended travel shocks there isnt much point to getting UCA's
  19. Jun 18, 2011 at 10:00 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    That's what I was just thinking, they are going to check the back order status and place the order for the longer icons, I really just want the ability to get a little wild and still drive home. ;)
  20. Jun 18, 2011 at 11:43 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    I would pay extra for the zinc coating. My only complaint is mine have oxidation. Didn't every wax em or whatever....
    I love my extended travel icons. I agree I like to get a lil wild and still drive it home.
