ID that Sound!: Clicking noise from behind the steering wheel at 3 mph only after engine start.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fj1608, Jul 14, 2023.
  1. Jul 14, 2023 at 12:21 PM
    fj1608
    fj1608 [OP] Member
    Any insight on what this noise could be? It only occurs right after engine start when placed into drive at around 3 to 5 mph. Sound in question is right before the end of the video coming from the behind the steering wheel. 2023 TRD Off Road
    https://youtube.com/shorts/NmfumoMk9LA?feature=share4
  2. Jul 14, 2023 at 12:23 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Doors locking.
    HondaGM likes this.
  3. Jul 14, 2023 at 12:28 PM
    Tacospike
    Two Trucks
    HondaGM likes this.
  4. Jul 14, 2023 at 12:33 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    All I heard was the doors lock.
    HondaGM likes this.
  5. Jul 14, 2023 at 12:34 PM
    fj1608
    fj1608 [OP] Member
    Man I wish it was that! They lock as soon as the car is placed into drive if unlocked at park. The sound is coming from just behind the steering wheel.
    HondaGM likes this.
  6. Jul 14, 2023 at 1:07 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Can't hear any clicking sound.
    Did you proof your recording before posting on YouTube?
    HondaGM likes this.
  7. Jul 14, 2023 at 1:26 PM
    fj1608
    fj1608 [OP] Member
    The sound was pretty faint compared to the rest of the noises. I gave the recording another shot. The video has the truck just started and already in drive and and the doors locked, the sound only occurs at 3 mph after starting the engine.
    https://youtu.be/HqAZ-4hKEHI
  8. Jul 14, 2023 at 2:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can't tell from the video, but there is an ABS solenoid self test that happens after you start driving, either in forward or reverse. The ABS unit on your Off Road model is on the firewall in the engine compartment behind the dash area. Most Japanese vehicles from the past 15 years do this.
    EDIT: heard the videos with headphones, definitely the ABS self test.
  9. Jul 14, 2023 at 2:35 PM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    Sounds like abs is kicking on
    HondaGM and fj1608[OP] like this.
  10. Jul 14, 2023 at 2:41 PM
    The_vue's
    18 cement
    On a slight hill mine would do this
  11. Jul 14, 2023 at 2:43 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If it is abs it sounds abnormally loud but normal enough not to ignore.
    HondaGM likes this.
  12. Jul 14, 2023 at 3:08 PM
    thman1
    thman1 Well-Known Member
    2023 TRD OR
    Interior LED’s TRD CIA OEM Blackout pkge
    To me it sounds like an actuator. I also have a 2023 OR and I can hear what sounds like an actuator either in reverse and or forward below or at 3mph. It only happens once after I engage the transmission.
  13. Jul 14, 2023 at 4:01 PM
    fj1608
    fj1608 [OP] Member
    Thanks everyone for the help so far! My main concern is that it is something that would need to be repaired down the road but so far it seems like it is something that goes along with the truck.
  14. Jul 14, 2023 at 5:55 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
  15. Jul 14, 2023 at 6:05 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    When I first start to move in mine I hear a pop …my 2009 ABS sounds more like a squish noise…
  16. Jul 14, 2023 at 6:18 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If you have the blower going for heat or ac in park or low rpms something also clicks under shifter everytime the idle increases to increase power for blower.
    fj1608[OP] likes this.
  17. Jul 14, 2023 at 7:10 PM
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    My 2019 has made that noise since 2019. No issues.
    fj1608[OP] and bkhlrTaco's like this.
  18. Jul 14, 2023 at 7:40 PM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I get a little relay click when I first pull away. Don't know what it is for but it must be for a reason.
  19. Jul 14, 2023 at 8:12 PM
    nightstrike
    nightstrike Well-Known Member
    What’s with the violent shift from park to drive?
  20. Jul 14, 2023 at 8:16 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    What year? I lean toward mounts or bushings 1st.
