ID these parts behind timechain cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jul 20, 2015.
  1. Jul 20, 2015 at 8:27 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Can you ID these three rather interesting parts that are behind the timing chain cover?
    1. The bigger sprocket on the crankshaft, dead center in the picture, the smaller powers the timing chain. It does not power anything yet it has teeth. Not sure it is really a sprocket then, is it?
    2. The little L-shaped protruding stud, or whatever you call it, right above it. It does not move. What does it do?
    3. The actuator next to the sprocket.
    Here is my WILD GUESS of what 1 and 3 are... Parts of VVT -- the actuator cocks the sprocket in its portion that doesn't have teeth, which retards the motion of the smaller sprocket that moves the camshafts. Laugh at it if this guess is wrong
  2. Jul 20, 2015 at 8:36 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I'm going to guess large sprocket is crank position sensor and sensor attached, the L shaped stud is a oil squirter.
    1MK and foampile[OP] like this.
  3. Jul 20, 2015 at 8:40 AM
    foampile
    Mid-Atlantic
    that makes perfect sense. i didn't check if it was actually a tube, just assumed it's a solid L, like an allen wrench, which really would not make any sense.
  4. Jul 20, 2015 at 9:29 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Spot on.
    You are going to want to remove the studs for reassembly of the cover, or drop the bottom (PITA), otherwise you will have a tough time getting the cover back on with the oil pump o ring, and not loose all of the FIPG when sliding the cover on . . . and end up with leaks. Ask me how I know.
    1MK likes this.
  5. Jul 20, 2015 at 9:36 AM
    foampile
    Mid-Atlantic
    the two studs protruding from the mating surface ?
  6. Jul 20, 2015 at 9:40 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Correct. I didn't do this, but reaped the problems I described above and had to drop the pan. This was suggested to me after the fact by a master tech.
  7. Jul 20, 2015 at 9:47 AM
    foampile
    Mid-Atlantic
    why couldn't you just guide the cover over the studs ?
  8. Jul 20, 2015 at 9:47 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    That sprocket is actually on the crankshaft.
  9. Jul 20, 2015 at 9:48 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    You can, and you will scrap the FIPG off the bottom mating surface, and likely slide the oil pump o ring off as well, and then . . . leak.
    foampile[QUOTED][OP] likes this.
  10. Jul 20, 2015 at 9:49 AM
    foampile
    Mid-Atlantic
    Yes, thanks for the correction. I meant "crank" but typed "cam"
  11. Jul 20, 2015 at 9:51 AM
    foampile
    Mid-Atlantic
    OK, makes sense. What is the name for driver bits that are like reverse torx (torx being male and the driver bit to undo this needing to be female) ?
  12. Jul 20, 2015 at 11:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I believe a 6mm 6 point socket will be a close enough size to remove the studs. They aren't in very tight. That is how I remove mine.
    Definitely remove those studs prior to re-installation. Also, once timing is set, turn the crank so that the sprocket is level. Then adjust the oil pump gear, in the timing cover, so that it is level and matches the crank's sprocket. Otherwise you be fighting it forever.
    foampile[OP] likes this.
  13. Jul 20, 2015 at 11:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Large sprocket is called the crank trigger wheel. The sensor is to the right of it in the photo.
  14. Jul 20, 2015 at 11:21 AM
    foampile
    Mid-Atlantic
    what does the crank trigger wheel do ?
  15. Jul 20, 2015 at 11:23 AM
    foampile
    Mid-Atlantic
    oh i see. it's a hack close enough to work...
  16. Jul 20, 2015 at 11:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Every thing is based off of crank position.
  17. Jul 20, 2015 at 11:37 AM
    foampile
    Mid-Atlantic
    So it is not an actuator like i thought but a sensor that reports to the ECU where the crank is in its revolution cycle, correct ?
  18. Jul 20, 2015 at 11:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct
  19. Jul 20, 2015 at 12:54 PM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    Inverse torx.
  20. Jul 20, 2015 at 2:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Be gentle, and if you cannot remove the stud with a 6mm, then definitely get this^^^
