Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 23, 2012 at 5:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It may be that my PIAA headlights are part of the problem I have right now. They are over 4 years old. Maybe its just that they aren't as good as they used to be. I wonder if they can get dimmer without actually breaking/burning out a filament?
    Getting together with Fam for a great meal and great conversation is one of the best things in life IMO. It ranks up there with sitting around the campfire with friends. :cheers:
    It is very unfortunate that commercialism is coming to dominate the time of thanks giving.
  2. Nov 23, 2012 at 6:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, mostly. Truth is, I want them to be as good as the low beam + fogs on the corolla and they aren't. :eek:
  3. Nov 23, 2012 at 6:09 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    don't most lightbulb manufacturers recommend replacing bulbs every year?
  4. Nov 23, 2012 at 6:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Of course they aren't :D haha
    Will be too bright to run all the time I think for that purpose.
    Could just be old bulbs as you stated earlier. Or you could buy some retro fit lights :cool:
  5. Nov 23, 2012 at 6:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think PIAA says 2 years. And yeah, these has definitely lasted longer than any others I've ever had. And thuth be told, they were awesome. Now, not so much.
    I haven't noticed so much with the brights. But can't really use them too much around here. Always some yahoo coming from the other direction.
    I did put a lot of effort into aiming them. I don't think its they are too high or too low.
    Because of the height of the headlights on the truck is so different from the height of the lights on the corolla, it is difficult to compare them in that way.
    When parking them side by side in the driveway, the most noticeable difference is the color temperature of the light. The PIAAs definitely put out a whiter light.
  6. Nov 23, 2012 at 6:32 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Here is a little better exposed pic of the 5" light bar its still in the fine tuning phase of life
  7. Nov 23, 2012 at 6:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have a huge amount of respect for the effort, regardless of the outcome.
    I would never fit and HID into my existing housings. They weren't designed for it. The light scatter is painful to look at. I hate that when I have to look at it in other vehicles and would not do that to others.
    Is anyone making "projectors" for the '01-'04s ?
  8. Nov 23, 2012 at 6:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Retros are different. It's fitting a projector into our housing. There was a couple guys making them yes.
    Just slapping in HIDs is dumb I think as well.
  9. Nov 23, 2012 at 6:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm sure he would make ya a set too.
    Pricey though..but damn they work good
  10. Nov 23, 2012 at 6:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea but Mike has wide PIAA510s for that..
  11. Nov 23, 2012 at 6:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am not as sure about that as I used to be. The ones in there now said 4,000 kelvin on the packaging. And I liked them much, much better that the stock ones when they were new.
    Right now, today, I'm liking the color of the corolla's lights better. I'm wondering it the color temp of the old PIAAs has increased since they were new? Doesn't seem likely tho.
    btw: 5 mm socket on a 1/4 drive ratchet will fix the aiming issue on your truck. Remind me the next time we get together.
    Probably a lot easier to buy a new set of PIAAs huh?
  12. Nov 23, 2012 at 6:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes..would be much easier..and cheaper :eek:
  13. Nov 23, 2012 at 7:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I might look into another set. I'm wondering if they make them at 3800 kelvin. Have to check that out.
    Did you end up purchasing one of those 20" lightbars?
  14. Nov 23, 2012 at 7:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I got 2 of them. Shipped today :D going on the sides of my roof rack.
    Also go 2 of the 3lrs
    And 12 LED modules for rock lights and 2 in my tent
  15. Nov 23, 2012 at 7:26 PM
    MTgirl
    Weesa
    trying to make it so that we can see your truck from space? :rolleyes:
  16. Nov 23, 2012 at 7:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Basically yes :D haha
  17. Nov 23, 2012 at 7:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sometimes, the whiter light is harder to see. I notice it most on wet, rainy pavement.
    What are 3lrs? Are those the ones I got? 6" long with 4 leds?
  18. Nov 23, 2012 at 7:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The 3lrs are 3" pods with 4 LEDs
    6lz are what I have on the rear of my bed rack and in the mirrors which are 6" long with 6 LEDs. I already have 4 of them.
    I going to use the 3lrs for camp lights on poles that extend up
  19. Nov 23, 2012 at 7:41 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Blue light works best in the snow. Amber works well too as long as it's kept low. The whiter the lights the more it will reflect and not "stick" to the road
  20. Nov 23, 2012 at 7:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Amber is great for dust
