Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 25, 2012 at 11:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be doable! I agree with less lights too haha does it fold too??
    Oh shut up! Haha you know what I meant. Bigger as in more steel used..sheesh.
    :eek: scary
  2. Nov 25, 2012 at 11:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :p
  3. Nov 25, 2012 at 11:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm actually thinking of redoing the corners of my roof rack..like cutting out the squares and angling it in..
  4. Nov 26, 2012 at 7:51 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    thats what she said ;)
    :pccoffee:
  5. Nov 26, 2012 at 8:19 AM
    BradyT88
    BradyT88 Well-Known Member
    Doesn't look like it. Just looks adjustible. Wouldn't matter though when the tent is up there though. It will have as big of a profile if not bigger.
  6. Nov 26, 2012 at 8:21 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    :pout: I haz pink puddle in my driveway...
  7. Nov 26, 2012 at 8:45 AM
    MTgirl
    Weesa
    its coolant, just not sure where its coming from :(
  8. Nov 26, 2012 at 8:50 AM
    MTgirl
    Weesa
    i think it had accumulated overnight in the skid plate. took a quick look under the hood and it was dry as far as i could see. the puddle was maybe 1/2 cup or so. i'll investigate at lunch today.
  9. Nov 26, 2012 at 8:55 AM
    MTgirl
    Weesa
    86k
    I was hoping to wait until spring for that
  10. Nov 26, 2012 at 9:00 AM
    BradyT88
    That makes for a great morning...:angrygirl: sorry lisa..
  11. Nov 26, 2012 at 9:16 AM
    MTgirl
    Weesa
    When I had to have the belt, seals, and pump replaced in my Subie it was about $800...I hope Toy wouldn't be much more than that.
  12. Nov 26, 2012 at 9:41 AM
    MTgirl
    Weesa
    :( Thanks. Hoping its something I can fix easily.
    600 is better than 800 but still a good chunk of money. Guess I know what I'm asking Santa for now...:rolleyes:
  13. Nov 26, 2012 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It'll definitely be slimmer.
    Plus you could easily take the tent off for more intense trails too
    :eek:
    Could be..or bad hose, cracked radiator, or freeze plug :rolleyes:
    I had my Tbelt done and all new belts with all new fluids and a water pump and it was like 6-700
    Njce
  14. Nov 26, 2012 at 9:57 AM
    MTgirl
    Weesa
    yes, I know you know all about coolant leaks ;)
    :lalala:
  15. Nov 26, 2012 at 10:55 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :tumbleweed: jury duty is boring. Sitting in a room with 200 other folks... waiting. :eek:
    Lisa, I'm betting hose fitting. Sounds like maybe a pressure leak. Will only do it when the truck is at or near running temp. Check for low fluid level.
  16. Nov 26, 2012 at 11:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :brianr:
    I'm a pro :p
    Yea I'd be willing to bet it's a hose too. E water pump hardly leaks when it does.
    Or there was too much water in the coolant and it froze causing so,ething to break..
  17. Nov 26, 2012 at 11:30 AM
    MTgirl
    Weesa
    only had to go to jury duty once, got let go. good thing too as it was a 2 week trial :eek:
    the leak isn't coming from the pump or from the front of the engine for that matter. i can't tell where its coming from but only the back half of my skid was wet seems to be dripping down just in front of the cross member and next to the driveshaft :notsure:
  18. Nov 26, 2012 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :eek:
    How's the back of the heads look :eek:
  19. Nov 26, 2012 at 11:56 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    My guess is water pump too. They seem to go more during the cold winter. Mine did.
    Last thing you want is the pump failing while your driving and causing it to overheat. If its running down the skid plate it sounds like its coming from the water pump area. I doubt its any of the hoses or lines. You would be able to notice that.
    Put your hand down there and see if you can feel the antifreeze
  20. Nov 26, 2012 at 11:57 AM
    Digiratus
    Roaming the PNW
    The RedHead
    There are a couple of freeze plugs in back there.
