Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Nov 30, 2012 at 7:26 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    hey is there any easy way to tell what the gear ratio is in the rear is on my taco?
  2. Nov 30, 2012 at 7:28 PM
    BradyT88
    BradyT88 Well-Known Member
    Since you are a 2nd gen you, if you are a 4wd or Prerunner 4cyl you are 4.10, if you are v6 then 3.73. If you are a non prerunner 2wd 3.35 or ? (can't remember the other) if you are an xrunner 3.15
    Just saw you are a trd offroad so you have 3.73's.
  3. Nov 30, 2012 at 7:29 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Mike knows what it is, if you look in your door jam at that white piece of paper there is a code that you look up online and itll tell you the gear ratio.
    I WAS going to go up into the mtns tomorrow and get a christmas tree but I didnt get my permit in time and the offices aren't open on weekends to I have to do it later. Fuck
  4. Nov 30, 2012 at 7:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Worse than it does now? :confused: :D
    I thought 4:15 was even more impressive.
    Only about 1st gens. When it comes to 2nd gens, Brady is a GOD and I bow to him. :bowdown:
  5. Nov 30, 2012 at 7:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    NEVER BACK DOWN MIKE! Be strong!
  6. Nov 30, 2012 at 7:54 PM
    BradyT88
    I think a bent bumper looks better than a huge gap between the tailgate and the hitch receiver. Pluse where would I put my license plate and still have it lit at night?
    "God, I hope this isn't a fucking water hole"
    I don't know shit about 1st gens... haha I'm learning because I'm the only 2nd gen here, but learning is slow because it doesn't apply to me as much.
  7. Nov 30, 2012 at 8:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ben, you do not need Lightroom. Elements is perfect for what you like to do. And that price is amazing, it will never be better.
  8. Nov 30, 2012 at 8:08 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    have you gone to adobe and looked for an update for hte raw plug in?
    BRB.....you have a t2i right? and what version of elements?
  9. Nov 30, 2012 at 8:11 PM
    MTgirl
    Weesa
    just need to know which release of elements...7 maybe?
    you have to download the update for the raw plug in specific to your camera and the release of elements, delete the existing plugin and replace it with the new, updated file.
  10. Nov 30, 2012 at 8:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This ^^^ You have to update it if your camera is newer than the version of Elements.
    Ben, what is the version number. Not when you bought it. Is it version 7?
  11. Nov 30, 2012 at 8:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :proposetoast:
    I'm still using v7 and love it. More than adequate.
  12. Nov 30, 2012 at 8:14 PM
    MTgirl
    Weesa
    is it sad that I have CS5 at home, elements 7 at work (to do ad layouts) and I actually prefer some of the functions in elements over whats available in CS5? :eek:
  13. Nov 30, 2012 at 8:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    BACK TO CAMERA SHIT! Swell...
  14. Nov 30, 2012 at 8:16 PM
    MTgirl
    Weesa
    :laugh: next time you get a chance to be at that computer let me or mike know and we can walk you through the process.
    :woot:
  15. Nov 30, 2012 at 8:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
  16. Nov 30, 2012 at 8:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :pout:
    k bye
  17. Nov 30, 2012 at 8:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    STFU Derp. :D
  18. Nov 30, 2012 at 8:19 PM
    MTgirl
    Weesa
  19. Nov 30, 2012 at 8:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    He said he was trying to do it on a PC. :notsure:
  20. Nov 30, 2012 at 8:24 PM
    BradyT88
    Good thing you are an ME. haha
