Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 1, 2012 at 6:07 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    What do new wheelers packs go for?
    Yeah im planning on getting some 1" or 1.5" shackles for my All Pro's. With the new cap or whenever i load up the bed, it sits level or i get a little bro lean. These springs broke in quick. Ive actually contemplated getting some Expos now :spy: Anyone want some All Pro 3" springs?
  2. Dec 1, 2012 at 6:08 PM
    BradyT88
    BradyT88 Well-Known Member
    My rear bumper prevents me from doing shit all the time!! Front bumper never has. I am of the opinion rear bumper before front now!! Too bad I ordered a front before I realized this...
  3. Dec 1, 2012 at 6:10 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Fun fact. I didnt know this, but the 95-97 leaf spring length is the same as the pre-95 trucks.
  4. Dec 1, 2012 at 6:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Almost 500 shipped without the AAL
    I've heard the standards don't hold weight very well
    Your a silly 2nd gen :rolleyes:
    Yep. That's why if I wanted Dakars I'd have to get the ones for the pre tacos
  5. Dec 1, 2012 at 6:25 PM
    BradyT88
    I don't see how a 2nd gen is any worse there than a 1st. Overhang past the rear axle looks pretty similar plus you guys were dragging your tow package just as much as I was in Moab.
  6. Dec 1, 2012 at 6:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I touched once. Ben like 4 times and he is on shorter tires.
    You can't be serious?? 2nd gen rear panels hang way lower then 1st gen.
  7. Dec 1, 2012 at 6:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Dec 1, 2012 at 6:33 PM
    BradyT88
    They may be a little lower but I don't think it is by that much. The bottom of rear doesn't appear to be any lower than the low point of the cab, just like a 1st gen appears to be.
    Then why do 1st gens still get them? haha
  9. Dec 1, 2012 at 6:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't know of anyone we know at has a high clearance..
    And ats it tho! The whole body is lower on a 2nd gen..:notsure:
    Either way the rear ends are much lower then on 1st gens
  10. Dec 1, 2012 at 6:49 PM
    BradyT88
    Oh, my bad you are right. I could have swore Jace's was, but i just checked and it isn't.
    I guess the 2nd gen bodies must just hang lower past the frame than 1st gens, which my 1" BL just helped that a lot, especially when I get a high clearance bumper.
    Yeah that rack is pretty nice. Looks very very similar to the baja rack I was looking at, although I think he paid less for his.
  11. Dec 1, 2012 at 6:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea looks beefier but I like the built in light bar hoop part too.
    I've only seen like 2-3 1st gens that have cut the bedsides.. Merits almost nothing due to the shackles tho.
  12. Dec 1, 2012 at 7:05 PM
    BradyT88
    2nd gens are the same way really. I was checking out Brant's and the shackles hang lower than uncut bedsides already. The only thing it nets you is more clearance at the bumper really since you can go to a thinner bumper.
    Yeah I imagine it is beefier but the weight bearing issue is in the mounting point to the cab, and both mounting setups look pretty much the same. Using the factory holes in the roof so it's probably not really anymore weight bearing, just heavier itself. Plus I don't really like the look of the LED bar up there... haha
  13. Dec 1, 2012 at 7:36 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I am rocking a HC bumper. It really depends on how you wheel. I push my truck to the max and that bumper has hit more rocks than brants tires.
    IDK if youve ever had lights obove the cab but if you do get spot cuz flood puts lots of light on the windshield and kills your visabilty
  14. Dec 1, 2012 at 7:37 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    My leafs are perfectly fine.
    But a front bumper would be bad ass!! And I could run over stuff and give no fucks. And actually the one trail I do in the desert I have to pick my line super careful or I ruin my bumper, it is a real problem lol
    Oh come on, what's this plan and how does my 4 banger ruin it?
  15. Dec 1, 2012 at 7:40 PM
    BradyT88
    Good to know. And see I forgot about Konsta's HC bumper. haha
    Pretty much all of the SIK guys have hacked their bedsides on all the rigs, Cherokees, 4 runners, Pre-tacos. But they also wheel/beat on their rigs harder than pretty much anyone on this site.
  16. Dec 1, 2012 at 7:44 PM
    BradyT88
    So my grandpa had recently purchased a car hauler that my Uncle now has. I would have to check if it can haul a Tacoma or if it is rated or just cars, but it would be cool if you met me in Poky, then we could load your Taco up on the trailer, haul it down to Moab, and split gas and then if I break something you could haul me back (or not becuase my weight alone is more than your Taco is rated for... the flaw in the plan) and if I didn't break anything I could just haul you back to Poky.
    Would work great if I didn't break anything, but I think we would kill your tranny trying to haul me back...
    Plus gas for the trip would be cheaper for both of us I imagine.
  17. Dec 1, 2012 at 8:20 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Bumper is done woot woot! Install tomorrow! Gonna be sweet. And i disagree for the buper thing. I would have smashed mine 100 times over if I had the plastic bumper in the front. My rear doesnt matter since the tow packege hits before the bumper does. but thats just how I wheel I guess. And yeah the All Pro standards suck with weight. I am trading a guy straight across, his Expos for my standards. He doesnt have weight and I do.
  18. Dec 1, 2012 at 8:26 PM
    BradyT88
    Pics?:)
    Yeah really in the scheme of things you just need both front and rear. If it wasn't for the tow package and the bull bar both my bumpers would be gone given what I have done.
  19. Dec 1, 2012 at 8:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh ya shit there is no way I could tow your truck. The 1st gen v6 couldn't even do that. Maybe we can find another dedicated tow rig?
  20. Dec 1, 2012 at 8:57 PM
    mh.meier
    The Doctor
    Commiefornia
    Same if it wasnt for lack of bumper I wouldnt have a bumper haha. and rear, well thats next. I will have pics tomorrow painted and installed.
