Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 27, 2012 at 7:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ben after doing some ready, im pretty certain its just going to be a ground issue.
    I ve read it could be from the head lights themselves or even just the small ground wire that comes right off the negative terminal and attaches right to the body next to it.
  2. Dec 27, 2012 at 7:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No its actually a secondary ground.
  3. Dec 27, 2012 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    could also be the switch itself..
    also Ben a ton of thread im reading on this have the solution just being new bulbs..which would be odd since yours are what..1 year old maybe??
  4. Dec 27, 2012 at 7:36 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    And if you do take it to the dealership. Which one. Teton in IF or me in poky?
  5. Dec 27, 2012 at 8:02 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    god I hate vodka. literally nothing I have tried to mix it with that actually masks the taste. But its what im stuck with, so fuck me.
  6. Dec 27, 2012 at 8:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lemonade man :D
  7. Dec 27, 2012 at 8:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I found something on my porch when I got home a few minutes ago.
  8. Dec 27, 2012 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :popcorn:
  9. Dec 27, 2012 at 8:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ill give the next cup a try with that. Ill add extra sugar lol
    ive got white grape juice and sugar and its not doing much lol
  10. Dec 27, 2012 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea what Mike Hard Lemonade is..i actually like that stuff...:anonymous:
  11. Dec 27, 2012 at 8:14 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    What'd ya get?
  12. Dec 27, 2012 at 8:16 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    beer is pretty much preferred over everything else...but oh well, at least the vodka is working lol.
  13. Dec 27, 2012 at 8:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Still don't like beer..Ill take a shot of hard alcohol any day.
  14. Dec 27, 2012 at 8:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ali and Ben made me this very kool blanket for my RTT. And it is coming in very handy at the moment too. When I got home the temp in the house was 49*
    I'm wrapped up in my new blanket... "snug as a bug in a rug" :D
  15. Dec 27, 2012 at 8:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm gonna remember this next summer. :cool:
  16. Dec 27, 2012 at 8:32 PM
    MTgirl
    Weesa
    Very nice
    Why so cold inside? :eek:
  17. Dec 27, 2012 at 8:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Must be rotgut vodka. Did you make it in your bathtub? :confused:
  18. Dec 27, 2012 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    very cool!!
    lol well i tried Marks stuff last time in Moab..haha
    im spoiled cause my dad LOVES good bourbon :D so ive gotten to try all kinds.
    bought some ryi last time..was interesting..much stronger after taste..
    something be bought was so nice, very smooth.
  19. Dec 27, 2012 at 8:36 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Vodka-water
    1 double-old fashioned glass (8oz.)
    Ice
    2 shots vodka
    1 lemon wedge
    1 lime wedge
    water
  20. Dec 27, 2012 at 8:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was gone for several days. Went to visit my sis for xmas. Turned the heater of completely while I was gone. Can get away with that because it isn't getting below freezing yet. I was kinda expecting 40* so 49* was balmy.
