Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 28, 2012 at 7:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Brady, I have to disagree with this.
    Granted it was 2 trucks but both were equipped almost identically except for rear ratio. Mark's truck and my truck are both autos with 3.4L, nornally aspirated v6s and 33s. He is regeared to 4.88s and mine is stock with 4.10s.
    I have driven both trucks on the same stretch of highway which includes an uphill and a downhill section as well as a flat section. Big difference between the two.
    On the trail is where the huge difference is. The crawl ratio is significantly better with the 4.88s, especially down hill. Mark's truck is able to idle down the trail, never having to touch the brakes to maintain speed. Engine braking is much more significant. Whereas, when I am behind him in the same section of the same trail, I have to apply brakes constantly to keep from over running him.
    Rather that say you are just wrong about this, I would say what you are experiencing may apply to your truck and 2nd gens in general. It seems to be very different on a 1st gens I have driven.
  2. Dec 28, 2012 at 7:20 PM
    BradyT88
    BradyT88 Well-Known Member
    I see. Could be a difference in the way the engines operate (modern engines are all about mpg and minimizing engine hold back will help improve fuel economy a lot). Mine holds back really well at high speeds (I think this is why my mpg went down, cant really coast anymore) but it is hardly noticeable at low speeds. The main difference is throttle response but again it is still not enough of an improvement to justify the cost of regearing. Crawlbox is cheaper and much more affective there. Regearing is good for getting lockers though:D and it is a great improvement to street driving.
  3. Dec 28, 2012 at 7:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Your both right..and wrong..do both :D like I'm gonna do :D
  4. Dec 28, 2012 at 7:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hmmm, that makes sense to me. One of the things I don't like any longer since going to larger tires is how much it coasts. And one of the things I noticed in driving Mark's truck was how it doesn't coast very much/far.
    I hope you are right about throttle response, I no longer haz that. Hope to change that soon.
    Why were you asking about 4.30s?
  5. Dec 28, 2012 at 7:38 PM
    BradyT88
    I can accelerate pretty nicely at half throttle, where as before it would practically take full throttle. I made a bigger jump than you though, well unless you go to 5.29's I guess. Haha I enjoy giving it a little extra throttle hear and there though;)
    Good hell... it is 8 degrees outside right now!
  6. Dec 28, 2012 at 7:45 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    http://montanabrewers.org/trail-map/
    you can get growlers filled up anywhere you know... :spy:
  7. Dec 28, 2012 at 7:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Find a nice, soft place to land because a growler will kick your skinny, light-weight ass. :D
    Oh, and once you go PIAAs, you can never go back to regular halogens. :cool:
  8. Dec 28, 2012 at 7:47 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    He also like to rub through stop lights
  9. Dec 28, 2012 at 7:49 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    back in good ol moscomption eh? how was the drive? or is that down in the south?
  10. Dec 28, 2012 at 7:51 PM
    MTgirl
    Weesa
    shhhhhh... :spy:
  11. Dec 28, 2012 at 7:58 PM
    Mudsaucecoma
    Andy
    boise, idaho
    god man you need to tell your woman to feed your ass.... your practically floating away!!! well now that your of legal drinking age,you will put on a few pounds. but your still going to need to work on gaining an ounce or two...
  12. Dec 28, 2012 at 8:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Think of how I feel! Haha no get up and go now.
    And thought I could get so,e for cheap but ended not being able too woulda swapped them in till 4.88s and 35s
    Trust me he eats plenty...
  13. Dec 28, 2012 at 8:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I still have your hitch pin.
  14. Dec 28, 2012 at 8:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :popcorn:
    Waiting for Ali to chime in here. :D
  15. Dec 28, 2012 at 8:04 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    How do you guys think the best way ti go about including a towhitch on the new bumper?
    Should I build it do I can use the stock one?
  16. Dec 28, 2012 at 8:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. Needs to be built in. Hangs too low otherwise.
    Like how Eric and Tim made theirs.
  17. Dec 28, 2012 at 8:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey, I totally know how it is. That is why I am regearing first. :stirthepot:
  18. Dec 28, 2012 at 8:07 PM
    MTgirl
    Weesa
    Pass the poppycorn please...
  19. Dec 28, 2012 at 8:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This VVV
    FIFY :cool:
  20. Dec 28, 2012 at 8:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Haha, Think it'll help? :eek:
    My guess is time itself will help. After all, we've all seen pics of his father. :laughing:
