Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 9, 2013 at 1:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you go small formfactor, I highly recommend the Uniden 520XL. Not too expensive, lots of features and seems to perform very well.
    If it was GREAT before (and it was), it'll still be good at the very least. Changes to the rack may have had some impact. We can check it again.
  2. Jan 9, 2013 at 1:51 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    X2 love my 520xl. Works awesome.
    And yea..hopefully not. It did work freaking epic good
  3. Jan 9, 2013 at 2:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Now that's impressive! Lol :p
  4. Jan 9, 2013 at 2:08 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Will the 520 fit in the change holder?
  5. Jan 9, 2013 at 2:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    haha, that is what that thing is for non-smokers.
    Yes, fits pretty good just slipping it in. :rolleyes: Tight enough on the sides to hold with no other mounting.
  6. Jan 9, 2013 at 2:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Walmart can do it.
    Hell it's even cheap to get an oil change at the dealership man. You don't really save that much by doing it yourself. Plus the dealership will do a full inspection while its there.
    I would not do it n the parking lot.
  7. Jan 9, 2013 at 2:27 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    FRIEND'S HOUSE :notsure:
  8. Jan 9, 2013 at 2:33 PM
    MTgirl
    Weesa
    why didn't you do it while you were home over the weekend? :rolleyes:
  9. Jan 9, 2013 at 2:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It'll be fine. Recommended you change 5k but in truth it'll last as long as 10.
  10. Jan 9, 2013 at 2:52 PM
    MTgirl
    Weesa
    Or you can be like moderator Ben and never ever change the oil :rolleyes:
  11. Jan 9, 2013 at 2:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's a Toyota..it'll run in oatmeal for oil lol
  12. Jan 9, 2013 at 3:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You are welcome to come over and use my garage. Its only about 40* in there but that is probably like a sauna compared to the wal-martian parking lot. :rolleyes:
    FWIW, I just changed mine last week (found some moab red in the process), it had a 6500 on it and was very black. I use M1, 5K is better.
  13. Jan 9, 2013 at 4:09 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ben just do it in your appt lot. Hopefully nobody will notice, if they do just tell them to go away lol. If u drain it quick enough, just tell people you are topping it off.
    Don't be a baby about it!!
  14. Jan 9, 2013 at 4:22 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    520XL and 4' fire stick in my shopping cart.
    :smack:6K!!!!!
    the 3.4 is in the sludge motor classification oil needs to be done every 3K. 5K is ok if its full syn. i run AMS oil and change it every 3K oil is cheap compared to a motor.
  15. Jan 9, 2013 at 4:53 PM
    MTgirl
    Weesa
    I need to get my camera out more....I haven't cleared my 8gb card off in over 2 months :eek:
    In the summer time I'm lucky if I don't clear it once a week!
  16. Jan 9, 2013 at 4:59 PM
    MTgirl
    Weesa
    Ben...I love ya but NO! :cool:
  17. Jan 9, 2013 at 5:09 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I just dropped some coin on a 128gig card for the gopro... now to start making mounts..
  18. Jan 9, 2013 at 6:17 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Go do it in the mountain view park parking lot!:D
  19. Jan 9, 2013 at 6:22 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    In mountain home?
  20. Jan 9, 2013 at 6:39 PM
    MTgirl
    Weesa
    :wave: Hi Phil...how goes the Taco shopping?
