Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 20, 2013 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    We definitely have some talented photographers in this group. A couple of fine photographs guys.
    155893_473694962671936_128693728_n_zps00_7e9203323fdb7175c58a284be87f665c956d84be.jpg
  2. Jan 20, 2013 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Most of the winch mfgs use 4 ga for the short run between the solenoid and the winch. But yeah, if I was to run winch power all the way to the rear bumper, I think 2 ga is a minimum. 00 might be overkill.
  3. Jan 20, 2013 at 9:21 PM
    BradyT88
    BradyT88 Well-Known Member
  4. Jan 20, 2013 at 9:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    shit i have 1/0 for just my amps :anonymous:
    But for the long run out back i would want it that big with out a doubt.
    and controllable solenoids.
  5. Jan 20, 2013 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    just get two 500 amp relays. One for the front and one for back. then just buy the wire.
    Idk what kinda plugs you could use..but im sure there are some nice ones.
    could be under 200 bucks easy. The relays would be 80ish. wire would be about 50 id think. and who knows about the plugs.
  6. Jan 20, 2013 at 9:28 PM
    BradyT88
    :rofl: I also have 1/0 for my amps. haha. They are in the trunk of my car though, so it is probably 10-15ft of wire.
  7. Jan 20, 2013 at 9:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its gonna be the light man. Its really yellow so check the white balance. Then id play with exposure maybe to try and get the darker grains..
    white balance will help though a lot. Then play with how light is hitting the gun.
  8. Jan 20, 2013 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    im glad i do now. Im using the power blocks to feed my CB and my lights and relays in the truck. Been very handy.
  9. Jan 20, 2013 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea thats gonna be tricky since it'll reflect a big spot of light right back to you. Probably need multiple indirect light sources..
  10. Jan 20, 2013 at 9:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not much info in that link. If the wire gauge is listed, I missed it. I'm guessing its 4 ga tho. Same goes for the amp rating for the solenoid. I'm guessing 80 amp which is inadequate IMO.
    Like Monte said, build your own kit.
    Ben, I have no idea.
  11. Jan 20, 2013 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea if you can get like at least 3 lights shining on it in a diffuse way it'll help.
  12. Jan 20, 2013 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    80 amp is way under..most winches spike to 480ish amps..
    building one will be better..plus..more custom :D
  13. Jan 20, 2013 at 9:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    they rarely do..
  14. Jan 20, 2013 at 9:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    More light on the subject will allow you to close down the lens so you have a greater depth of field. In this pic, the DOF is so narrow part of the engraving os out of focus. Same goes for the long barrel shot.
    I actually like this shot for what it is but you need to be at F8 or F9 minimum to get more area in focus. Are you on a tripod?
  15. Jan 20, 2013 at 9:47 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  16. Jan 20, 2013 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    enter Mark :laugh:
  17. Jan 20, 2013 at 9:59 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the real beauty of these things gotta be seen in person to be really appreciated.
    we got the special edition NRA 1911 last year...cant capture how awesome it is in a pic
  18. Jan 20, 2013 at 10:00 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I feel so dumb when you guys talk about camera stuff lol
  19. Jan 20, 2013 at 10:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm afraid not buddy. You'll never get there doing that. Not on flash in any case. If you go to high on ISO you loose quality that way too. :eek:
    Either broad daylight or tripod. Those are the choices.
  20. Jan 20, 2013 at 10:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I just say words and eventually the topic changes :cool:
