Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 8, 2012 at 10:13 PM
    #2641
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    sweet! pic or it didn't happen
  2. Feb 8, 2012 at 10:19 PM
    #2642
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    1st gens don't have that setting. Its either 0 or 1.25 or 2.5.
  3. Feb 8, 2012 at 10:23 PM
    #2643
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i know nothing about 1st gens
  4. Feb 8, 2012 at 10:33 PM
    #2644
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Or 2nd gens :rolleyes:
  5. Feb 8, 2012 at 10:34 PM
    #2645
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    always a hater monte what's wrong did you not have your juice box today?
  6. Feb 8, 2012 at 10:35 PM
    #2646
    Blackdawg
    Monte
    Wyoming/St. Louis
    nope :pout:
    no juice for me :(
    lol :D
  7. Feb 8, 2012 at 10:37 PM
    #2647
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Don't worry I'll bring a sippie cup and some pacifiers for you to moab.
  8. Feb 8, 2012 at 11:00 PM
    #2648
    Blackdawg
    Monte
    Wyoming/St. Louis
    Aww gee thank buddy! your the best hahahaha
  9. Feb 8, 2012 at 11:39 PM
    #2649
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    so im trying to figure out if the 33s will rub on the ucas, and i have come to the conclusion that with a 1/4" wheelers spacer i should be fine and dont need to worry about it
  10. Feb 8, 2012 at 11:50 PM
    #2650
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    make sure you get longer studs so you don't snap them off
  11. Feb 9, 2012 at 12:04 AM
    #2651
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    aaaaaaaaaaand the first parts in my 3 month build scramble have been ordered! firestik antenna, coax cable and side mount. i will have a cb by the time they arrive and i can begin an install.
  12. Feb 9, 2012 at 12:20 AM
    #2652
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I picked mine up at wally world for 30 bucks
  13. Feb 9, 2012 at 12:42 AM
    #2653
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Nope, they wont rub on your uca's. My 11.2 wide tires are a finger away from the uca and have only rubbed once or twice
    Thats a 16x8 wheel too
  14. Feb 9, 2012 at 1:02 AM
    #2654
    Blackdawg
    Monte
    Wyoming/St. Louis
    You don't want to run that type of spacer, trust me, the front studs are short enough as it is.
    Hub centric spacers are the only way to go for spacers.
    and i am pretty sure we have gone through this like multiple times with you lol your just getting 33x10.5s right? 4.5BS would be enough for 10.5 wide tires and you could even just use your stock rims. If you get 33x12.5s, you need an 8'' wide rim and 3.75 BS is best. Even with my 8'' wide rims with 4'' BS i didn't rub on the UCA.
  15. Feb 9, 2012 at 8:21 AM
    #2655
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya ya ya I know, ian came in telling me I was going to rub frame so I started askng stupid questions again. Ill shut up now. Not sure if u already posted it adam but what kind of radio
  16. Feb 9, 2012 at 9:09 AM
    #2656
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yeah im not sure anymore, haha. I cant remember the BS on the stock 15" wheels. But i think it will be really close.
  17. Feb 9, 2012 at 10:14 AM
    #2657
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    its a cobra something it's cheap but it will get the job done
  18. Feb 9, 2012 at 11:09 AM
    #2658
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    these are my leafs. they from what i see they still look good and have some arch. so an AAL is perfectly fine, concur?
  19. Feb 9, 2012 at 11:13 AM
    #2659
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    So if you have a jailbroken iPhone you can get " Safari upload enabler" from cydia then you can upload pics to TW or any other site.
  20. Feb 9, 2012 at 11:34 AM
    #2660
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yep looks good man! AAL will work perfectly fine.
