Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 19, 2013 at 9:45 PM
    BradyT88
    BradyT88 Well-Known Member
    Is Mark running stock coils? I thought he upgraded, or was that just shocks he upgraded?
  2. Feb 19, 2013 at 9:49 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Thanks guys:D I love it!
    Everything is done, just want to mill our some holes that dont line up quite right and need to paint it (then later on make my light hoops) But yes, there is a gap there, nothing is out of line, must just need some more fill plate. Where would you guys suggest it at? The opening in the middle is of course for a winch, but where you you guys suggest to plate up? The inside of the wings? underneath the grille so the hole in the middle is smaller?
    edit: k, so after looking at pics of other bumpers it looks like a lot of them have the top part plated over/sealed in. Im guessing its open for ease of access to the winch but if you can get to the winch (that I dont have, and wont have for a while) with the top covered then I guess ill see about boxing in the top part. All of it or just some of it?
  3. Feb 19, 2013 at 9:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yyyyaaaaaaaaa:anonymous:
    about that. Stock coils were fine last year...now with this thing....it took a nose dive haha! And andy has the coils just sitting around.
  4. Feb 19, 2013 at 10:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sounds like lots of fun!
    So glad you did
    :pout: Too bad. Bad timing for me.
    Looks good Mark. Has potential. Fill that gap up with a winch.
  5. Feb 19, 2013 at 10:04 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    if only. Many other things are on the list in front of that.
  6. Feb 19, 2013 at 10:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Have you thought anymore about hells canyon in may?
  7. Feb 19, 2013 at 10:14 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I hate geography...
    Ben were you trying to intern at?
  8. Feb 19, 2013 at 10:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Probably the day before. :rofl:
  9. Feb 19, 2013 at 10:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Geography is easy. Engineering is hard. :cool:
  10. Feb 19, 2013 at 10:18 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    here we go, this is how I am going to fill it in. Just need to get a thin sheet of steel and get it cut out.
  11. Feb 19, 2013 at 10:19 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Engineering is easy lol I hate geography. I hate rock, minerals, all of it lol. For wanting to be a petroleum engineer im as dumb as a sack of rocks( pun intended) when it comes to the geo part. Like I dont care why the stratigaphic separation across a fault would be the same as vertical seperation lol thats what they pay the geologist for.:D
  12. Feb 19, 2013 at 10:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    But you gotta know a little when they are talking to you. Or you'll look like this:
  13. Feb 19, 2013 at 10:29 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Lol thats how i already feel.
    We got a geo lecture exam, then a geo lab exam both tomorrow. Im just gonna draw a pretty picture on it.
  14. Feb 19, 2013 at 10:29 PM
    BradyT88
    I would say plate the top, but it looks like you will have to cut that back out to fit a winch later when you get one. Other than that looks good Mark:D
  15. Feb 19, 2013 at 10:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Only 1400 more for the custom axles :rolleyes:
    Probably would fit..but wouldn't help a ton. His best bet is just getting eibachs they are cheap enough.
    Told ya :p
    But glad it's done. Will look nice painted. Now get those eibachs :D
    Fuck yea :cool:
    :cheers:
  16. Feb 19, 2013 at 10:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol may e ill drive a different car then Frankenstein...
  17. Feb 19, 2013 at 10:40 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well should I get one the winch could always just slide in from the back. But honestly I dont see myself getting one in a very long time.
    and monte, the 2nd gen coils have to help out a bit, they are beefier and hold up more weight.
  18. Feb 19, 2013 at 10:53 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Naw your fine. I know seniors this year that havent ever had one. I just got lucky with my first 1, which opened the door for my 3rd one with this new company.
  19. Feb 19, 2013 at 11:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They are 550lb coils..
    Yours are around 500
    They will help a bit...
    Not a ton though..
    Wouldn't put them at 2.5 on the 5100 either as I think they are a bit longer. So you still wouldn't beget as much lift.
  20. Feb 19, 2013 at 11:01 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    fuck
