Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 22, 2013 at 9:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's why 4.88s are the miracle cure.
  2. Feb 22, 2013 at 9:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :brianr:
    Yep, I was the highest :eek:
    Lol no they aren't they increase rpms for us. Would put me at almost 3000rpm for 65..3400 with 4.29s..75 would never happen haha that would suck..
  3. Feb 22, 2013 at 9:54 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    just throw some 7.20s in there and 50 MPG will be a dream. but you'll get there quickly
  4. Feb 22, 2013 at 9:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :der:
    Ummm....
    No haha
    Would be like 5 grand in 5 gear to go 40mph...haha
  5. Feb 22, 2013 at 9:56 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    just get a 4 banger, thats the best solution.
  6. Feb 22, 2013 at 9:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    May be but I still think they are the right choice for you. 4,56s are too little for 35s and and 5.29s are tooo much.
  7. Feb 22, 2013 at 10:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    5.29s aren't too much with 35s. What Jon has. He doesn't love it on the hwy, but works great offroad..
    Idk though. Can't afford it anyways haha
    Wasn't mine?? :notsure:
  8. Feb 22, 2013 at 10:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Was there math involved in figuring that out? :confused:
  9. Feb 22, 2013 at 10:50 PM
    BradyT88
    BradyT88 Well-Known Member
    5.29's would put you 1st gen 5 spd guys at about 3000 rpm at 65 mph on 33's and about 2800 rpm on 35's.
    4.88's would put you at about 2700 rpm at 65 mph on 33's and about 2550 on 35's.
    I run just over 2300 at 65 mph. 35's would drop me to about 2200 rpm/
  10. Feb 22, 2013 at 10:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    But covering more distance per revolution.
  11. Feb 22, 2013 at 10:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea so 4.88s would be like stock gearing ish.
    So 4.88s might be the way to go
  12. Feb 22, 2013 at 10:55 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Thats what im thinking
  13. Feb 22, 2013 at 10:55 PM
    BradyT88
    I think you should always overshoot stock. Sure stock would get your rpm's back but you have more rotational weight from the tires now so you won't get the stock feel back. I'm a big fan of just overshooting stock and getting a better than stock feel to the rig. Love my 4.88's! Could only imagine how awesome 5.29's would be!
  14. Feb 22, 2013 at 10:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No 4.88s and 35s would be like stock. 4.88s and 33s is over stock.
    I figure by the time I go 35s ill have a crawl box or one right after them anyways.
  15. Feb 22, 2013 at 11:04 PM
    BradyT88
    Gears are for high speed driving, particularly the other 90% of the driving you do as Ben calls it. Sure they may help you guys save your clutch a little offroading but I think the gain is minimal cuz the change is so minimal at low speeds. Crawlboxes are where it is at for offroading.
    4.10's would have put my 33's back to factory. 4.88's would need 40's to achieve factory rpm's for me.
  16. Feb 22, 2013 at 11:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Even so, 4.88s and 35s will be better then what I have now haha
  17. Feb 22, 2013 at 11:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Makes sense..
    I still swear I was just a touch higher then you for so,e reason..oh well
  18. Feb 22, 2013 at 11:15 PM
    BradyT88
    Oh yeah!:cool:
  19. Feb 22, 2013 at 11:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    But you are starting from 3.73s while we are starting from 4.10s. I lot of the difference you are calling out is right there. Add to that, your v6 churns out more HP and torque than ours.
    Makes all the diff.
    And Ben, Why are you quoting the pic of Phil's truck?
  20. Feb 22, 2013 at 11:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So expensive tho...haha
