Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 28, 2013 at 10:36 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  2. Feb 28, 2013 at 11:08 AM
    BradyT88
    BradyT88 Well-Known Member
  3. Feb 28, 2013 at 11:22 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  4. Feb 28, 2013 at 11:44 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I know dat guy
  5. Feb 28, 2013 at 1:16 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'll let you know if i have a rig or not. If i do I'll have to built it and roll out.
  6. Feb 28, 2013 at 1:32 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Sounds great my friend! Im sure you dont need to have it built up to the extent you did last time, a bumper sliders lift tires, and a radio should suffice. Gotta put on your big boy pants for this one, I plan on doing harder trails than we did last time.
  7. Feb 28, 2013 at 1:37 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you ready for that without a locker?
  8. Feb 28, 2013 at 1:38 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya. adam and everyone else was saying I would be fine, might just need a tug on a couple of spots.
    Adam knows trucks and he knows the trails, and if he says go for it I trust him.
  9. Feb 28, 2013 at 1:39 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Behind the rocks was fairly difficult compared to the other trails we did. but i didn't do kanes creek. I hear that was rough.
  10. Feb 28, 2013 at 1:41 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    sweet! I would definitely like a longer wheel base than the rg cab had it was just short enough that i got hung up a few times
  11. Feb 28, 2013 at 1:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    we are doing all of that one, and it just gets worse lol!
    hahaha yup, the x cabs are a good wheel base I think, not too long or short
  12. Feb 28, 2013 at 1:54 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i think the T4r and the x cab wheel base is close if not the same I'd like covered storage
  13. Feb 28, 2013 at 2:06 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Correct. T4r are basically the same truck.
  14. Feb 28, 2013 at 2:15 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Monte your sig pic broke
  15. Feb 28, 2013 at 2:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I see it?
  16. Feb 28, 2013 at 2:17 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
  17. Feb 28, 2013 at 2:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really?? Weird.
  18. Feb 28, 2013 at 2:32 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    me neither
  19. Feb 28, 2013 at 2:48 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    you have exceeded your bandwidth
  20. Feb 28, 2013 at 2:48 PM
    BradyT88
    I see it still. Although maybe he fixed it already. haha
