Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 2, 2013 at 12:38 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  2. Mar 2, 2013 at 2:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Brady. 76.5" wide from tire to tire.
  3. Mar 2, 2013 at 3:40 PM
    BradyT88
    BradyT88 Well-Known Member
    I'll try to measure mine tonight. Did front and rear match?
  4. Mar 2, 2013 at 3:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just did rear. Front tires aren't straight and my motor isn't able to run. Ill get front later if ya want
  5. Mar 2, 2013 at 3:43 PM
    BradyT88
    Ok. Depends on how different my front and rear are I guess.
  6. Mar 2, 2013 at 5:37 PM
    BradyT88
    Rear was 75" and front was 75.5". I didn't widest part of tire to widest part of tire. KM2's don't have a very wide tread pattern. haha.
  7. Mar 2, 2013 at 6:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    what? you did the tread pattern or the widest part of the tire? i did the widest part..so..give or take .25'' or so..
  8. Mar 2, 2013 at 6:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I really like the stance, tires don't bother me.
    Ben, the truck is looking good.
    I don't recall ever saying shit like that. :confused:Gotta do what you gotta do. Besides, you were by yourself.
    This ^^^^
    From the widest part (sidewall). Front is 73" and back is a little less, ~72.5".
  9. Mar 2, 2013 at 6:49 PM
    BradyT88
    Widest part. What is the backspacing of your wheels and width of your spacers and are your tires truly 12.5" wide?
    I haven't actually measured my tire width but it's got to be pretty close to 10". My backspacing is 4.5" and I don't have spacers.
  10. Mar 2, 2013 at 6:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow im way wider then you! lol
    so they are 1'' out wider then stock...
    and im a lot closer to you then i thought..
  11. Mar 2, 2013 at 6:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
  12. Mar 2, 2013 at 7:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  13. Mar 2, 2013 at 7:16 PM
    BradyT88
    1.5" is all.
  14. Mar 2, 2013 at 7:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    for now haha
    be 3'' before too long :eek:
  15. Mar 2, 2013 at 7:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :notsure: I am flexible. This spring? May? June?
  16. Mar 2, 2013 at 7:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    map isn't loading for me :eek: and i can't watch movies till im home from work.
    But, would snow be an issue??..
    how many days you think?
  17. Mar 2, 2013 at 7:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, sno will be an issue, especially the 1st segment which goes between Mt St Helens, Mt. Adams and Mt. Rainier.
    I'm thinking 3 campfires should do it. :D
  18. Mar 2, 2013 at 7:38 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I could go for a good campfire 'bout now.....
  19. Mar 2, 2013 at 7:41 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Its beautiful here in spokane this eve, I think it was around 50 @ dusk...
  20. Mar 2, 2013 at 7:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    so 5 day trip for me..hmmmm...
    like..mid June? or late June maybe? to try and give a better shot at snow?
