Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 7, 2013 at 9:50 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    :rofl: Monte's really getting to Ben standards with the typos lately
  2. Mar 7, 2013 at 9:50 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Seems he is.....
  3. Mar 7, 2013 at 9:52 AM
    MTgirl
    Weesa
    I'm not sure that I even want to know what a "group but" is! :eek:
  4. Mar 7, 2013 at 9:55 AM
    mh.meier
    The Doctor
    Commiefornia
    I dont either, especially when but is only spelled with one T!
  5. Mar 7, 2013 at 10:21 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hey..draws more attention!
  6. Mar 7, 2013 at 10:32 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    destiny looks sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
  7. Mar 7, 2013 at 11:29 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    For the sole reason of destroying ben
  8. Mar 7, 2013 at 11:58 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I had a Amazon coupon so it only cost me 10 bucks haha
  9. Mar 7, 2013 at 12:10 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Bastard
  10. Mar 7, 2013 at 12:19 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Bigger bastard
  11. Mar 7, 2013 at 12:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    past tense danger signs
  12. Mar 7, 2013 at 12:26 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I had a girlfriend thats why I have $0 turtle beaches!
  13. Mar 7, 2013 at 12:27 PM
    BradyT88
    BradyT88 Well-Known Member
    Hmmm... That video was interesting. haha. I don't think I would use that to argue the skinny vs wide debate though, because we don't know many of the factors. First they based contact surface off of the rating and not the actual measurement. My tires are rated at 10" wide but only have a 7" wide tread pattern. Secondly the psi in the skinny tires was much higher (at least they seemed to imply it was) than the street tires, so the skinny tires are automatically going to have a smaller contact pattern on the ground causing the low traction situation that put them in.
    I'm pretty confident that if you match vehicle weight and psi in both situations and then compare skinny to wide, you will find that skinny tires will provide more lateral traction and wide tires will provide more forward traction.
    If you are having issues with lateral traction, either add more weight, let some air out, or do both.
  14. Mar 7, 2013 at 12:28 PM
    BradyT88
    Had?:eek:
  15. Mar 7, 2013 at 12:29 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    GENTLEMAN!
    I will be renting black ops 2 tonight and me and my room mate and his friends will be playing it, so cody, mac, ian i think...all you fuckers should join in this evening!
  16. Mar 7, 2013 at 12:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Amazon
    im in the ocean
    wont have it for another several years
  17. Mar 7, 2013 at 12:59 PM
    BradyT88
    The only think I can think of, is that they run those wider tires so they can race at lower psi's in general without flexing out the tire. A lower psi will give them a better contact patch with the road and should result in better traction. Same reason why we drop our psi to offroad, but we can offroad with flexed tires. I imagine racing on flexed tires could result in throwing a bead easier or allow the car to shift on the sidewall while cornering.
  18. Mar 7, 2013 at 1:04 PM
    daddoo
    daddoo Member
    Greg
    Tooele
    08 Tacoma access cab
    Leveling kit, wheels and tires, Topper, Alpine stereo
    Im new to the forum and a first time Taco owner. I've had my truck about 2 weeks and looking to get started building and modifying my truck. Money is a huge issue so if any one has and good ideas and sources to help out it would be appreciated.
  19. Mar 7, 2013 at 1:08 PM
    BradyT88
    Welcome! Glad you made it over to this thread:D There are several discounts through vendors and such from this website so just let us know what you are doing to do first, or next or whatever and we can try to steer you in the right direction.
  20. Mar 7, 2013 at 1:09 PM
    BradyT88
