Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 7, 2013 at 1:35 PM
    BradyT88
    BradyT88 Well-Known Member
    Because at 15-20 psi a skinny tire would flex more and my guess is flex is bad for racing. Easier to throw a bead for 1 but bead locks would fix that easily. Only other thing I've got is that the car could shift left or right more while cornering since the tire will be squishier.
    All of that is a guess. Haha. I really don't know what the reason is for the wides up front.
  2. Mar 7, 2013 at 1:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    F1 car stuff as nothing to do with ours
    They run a very hard side wall to keep the tire from flexing and ballooning at high speeds.
  3. Mar 7, 2013 at 1:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    See above ^^
    The run the wider tire for the most contact. But lower profile.
  4. Mar 7, 2013 at 1:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Side walls aren't even close to the same is my point.
  5. Mar 7, 2013 at 1:47 PM
    BradyT88
    You have to have the same psi. If you weigh 1000lbs, at 10 psi you will have 100 sq. Inches down. At 20 psi you only have 50 sq. Inches so you have half the contact area.
    A skinny tire will have a longer but narrower contact pattern than a wide tire. If contact total is the same then longer pattern will have better lateral traction and a wider contact pattern will have better forward traction.
  6. Mar 7, 2013 at 2:12 PM
    BradyT88
    Tires can only gain so much width from flex. Stronger sidewalls will flex less also forcing the tire the lengthen the contact pattern as well. Unless it is strong enough to just hold the weight up itself.
  7. Mar 7, 2013 at 2:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right but they aren't the same. Im not saying they are solid. But your basically trying to compare like..my tire to a low profile car tire..its stupid and pointless. They aren't the same thing.
  8. Mar 7, 2013 at 2:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wish i knew what that felt like..hell 0-60 in 3 seconds would be amazing to feel.
  9. Mar 7, 2013 at 2:32 PM
    BradyT88
    I want to get in some snow and measure my contact pattern at different psi. The tread depth on my km2's is so deep that my tires have to be pretty much flat before the sidewall is touching the ground so I dont think my contact pattern widens out much. Tire flexes but the flex is still off the ground.
    What is your dads 0-60?
  10. Mar 7, 2013 at 2:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    really? my side walls contact at like 15psi..must be due to C rated.
    idk :notsure: No where near 3 seconds lol its a big truck. probably around 6-8 though.
  11. Mar 7, 2013 at 2:44 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Today was a good day.
    Doritos Locos cool ranch tacos.
    And my professor that I work for is a badass. Hooked me up with this bad boy.
    And some cigars:spy:.
    Dont know how to make it smaller lol
  12. Mar 7, 2013 at 2:53 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    he gave you a jewelry box? :confused:
  13. Mar 7, 2013 at 2:55 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Better. Humador.
  14. Mar 7, 2013 at 4:42 PM
    BradyT88
    Could be the C vs E. I'll have to test it again to see.
    Really? I think my 0-60 is 8-9 seconds, well was, not sure about now with the armor. I know of some stock 2nd gens that can run 7-8 second 0-60's with a good launch.
  15. Mar 7, 2013 at 5:44 PM
    C2T
    C2T Well-Known Member
    Richard
    Helena Montana
    Yes...it's a JEEP!
    35" Tires, AEV front recovery bumper, 2.5" AEV lift, Certified Mall Crawler sticker, Warn 9500 winch, Hi-Lift, Air compressor.
    JEEP!!!
  16. Mar 7, 2013 at 5:54 PM
    BradyT88
    Just Empty Ever Pocket (for) Every Repair - JEEPER:rolleyes: Just kidding man:p I'm just not a Jeep guy. There are some badass looking Jeeps out there, but I just like trucks.
  17. Mar 7, 2013 at 6:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Nkorea just ended their nonagression pact with the south
  18. Mar 7, 2013 at 6:12 PM
    BradyT88
    Fucking stellar...
  19. Mar 7, 2013 at 6:19 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    "US can defend against Nkorean attacks", a few hours later... no shit
    my intel and ADA friends are gonna start drinking coffee again
  20. Mar 7, 2013 at 6:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    theyre butthurt that the UN's butthurt over their nuke tests
