Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 9, 2013 at 9:41 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    There ya go. Im probly sitting pretty close to what you are with my 265's
  2. Mar 9, 2013 at 9:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Except when you consider the BB skid does not fit flush up against the tcase. There is a least a .5" gap.
    Frame to ground at the rear spring hanger is 19". At the point the frame curves inward on the front it measures 18.5" :cool:
    Where are you boys measuring from?
    edit: rear spring
  3. Mar 9, 2013 at 9:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You will find that it varies quite a bit depending on where you measure from
  4. Mar 9, 2013 at 9:51 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    x2
  5. Mar 9, 2013 at 10:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I measure in four places. About where the front of spring hanger is on the rear and about where the front end of the slider is welded to the frame. Both frame rails.
    If your truck has taco lean, it will show up. If you have rake or bro lean, it will show up in your measurements.
    For example, mine:
    Driver side Passenger side
    Front 18.4" 18.6"
    Rear 18.9" 19.0"
  6. Mar 9, 2013 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not tonight but very recently. I keep a history of these things. :eek:
  7. Mar 10, 2013 at 10:34 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    DAMN!
    i need to swap my new filter in..and new oil filter too.
    i forgot man sorry. I'll do it today
    yea mine will be very different with the rake i have.
    Ill do front of frame. door side. rear frame and cross member.
  8. Mar 10, 2013 at 11:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Alright.
    From cross member im at 16 9/16s
    Front of frame before it toes inwards im at 19.5
    driver side door im at 20.5
    about an inch or two before the rear spring hanger im a 21.5
    so that was a lot more then i was thinking it would be.
  9. Mar 10, 2013 at 11:31 AM
    BradyT88
    BradyT88 Well-Known Member
    Had an awesome day wheeling in Shelly yesterday!! I really pushed my Taco hard! For the most part I kept up with a Jeep on 37's! Mostly. haha. I definitely bypassed a few things he did and he wasn't trying to push his rig too hard since he hasn't owned it very long. Working on some pics now. Don't have many though since I didn't have Cameron or Ben with me and I just had my phone. If I had had my rear bumper and skids, I probably would have tried to follow that Jeep the whole way:D but as you will see in the pics, my rear bumper kept holding me up bad... So much scraping... haha
  10. Mar 10, 2013 at 11:37 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    y not remove it???
  11. Mar 10, 2013 at 12:10 PM
    BradyT88
    I was able to just push it right back into place pretty easily. Well mostly back into place. To some degree is is still protecting my backend and I should be going to Colorado in a couple weeks to get my HC rear bumper. Plus I already don't have a front plate. Don't want to have to use magnets or wires to hang my rear plate. haha
  12. Mar 10, 2013 at 12:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Isnt ID a front and back plate state??
  13. Mar 10, 2013 at 12:30 PM
    BradyT88
    Yep. haha
  14. Mar 10, 2013 at 12:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So is Wy lol Took about 6-7 months till i go pulled over.
    I just keep it in the windsheild now.
    and yea Ben..once you and Mike posted numbers i didn't think mine would be that much higher.
  15. Mar 10, 2013 at 1:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea and my rear lift. I have more then you and mike by quite a bit.
    and stretch the legs of the tacoma lol..not even possible haha
  16. Mar 10, 2013 at 1:04 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Whats your guy's front hub center to wheel well? And front ground to wheel well?
  17. Mar 10, 2013 at 1:06 PM
    BradyT88
  18. Mar 10, 2013 at 1:16 PM
    BradyT88
    Yeah... He ran out of washer fluid... I really wish we would of got a video of that. I'll bet it was hilarious to just watch me burying him in that mud.
  19. Mar 10, 2013 at 1:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hmm idk. Mine would be different then everyones tho cause i have glass fenders
    i can go fast..just..scary now haha not fun.
  20. Mar 10, 2013 at 4:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben i know you'll like this video. Mike too.
    http://vimeo.com/55073825#
    really cool space shots. Also just awesome. Makes you really appreciate Earth
