Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Mar 27, 2013 at 12:14 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    or you could get the right fucking clamp.....:D.... very easy to do... available at NAPA......
  2. Mar 27, 2013 at 12:17 PM
    scocar
    scocar hypotenoper
    Dude, not funny. My right turn signal went bad right after I put my 881s on.
  3. Mar 27, 2013 at 4:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :woot:
    just got my plates!! Gonna drive it to the gym today! :yay:
  4. Mar 27, 2013 at 4:40 PM
    BradyT88
    BradyT88 Well-Known Member
    Thanks man!! Hopefully I can get away from the in-laws early enough tomorrow to get to CO at a decent time. 8 hours if I only stop for gas once. I'll likely stop for gas twice and to get food and bathroom breaks.
  5. Mar 27, 2013 at 8:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I know I can be dense at times, but I don't see the problem here. :confused:
  6. Mar 27, 2013 at 8:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    But tearing boots goes with the territory. :confused: When you lifted it you knew this could happen.
    I've always wondered what the long term effect of the boot slide mod was going to be. Seems like a bogus solution to the problem. Now that I think about it, everyone I know that has done it has ended up tearing boots.
    Kona, did you do the boot slide mod?
    Monte, you?
  7. Mar 27, 2013 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes I did. Although idk if either where a result if it. As one if mine tore in the roll and then the other I didn't do the inner boot for some reason which tore..
    Kona did it too
    Also I'd like to add Ben I told you you would have boot issue without some weight up front...
    Soooo....
    I told you so :p
  8. Mar 27, 2013 at 8:24 PM
    BradyT88
    That boot looks pretty stretched. I wonder if you should have slid the boots in a little when you lifted the front a little more.
    The boot slide mod is what caused mine to tear... I apparently slid the passenger side one too far. Didn't realize it when I did it but after I took it for a drive it caused the boot to wrinkle inwards on itself. I attempted to fix it but no matter what I tried I couldn't get the wrinkle out so I gave up. Didn't think it would cause my boot to tear but that is where it tore though.
  9. Mar 27, 2013 at 8:24 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Im not saying the hose clamp is a terrible idea...but I think it would fit and tighten down a lot more with the proper clamp and clamping ratchet thingy.
    Toyota cars and Honda atvs the CV axles are a pain in the dick to get out the differential (my experience) but they come out when you least expect it and you end up on your @ss in about .001 seconds lol
  10. Mar 27, 2013 at 8:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha yours is probably lifted almost 3" man. You have bro lean with a 2" AAL and the front of our rigs sits 1" lower up front. Your well past 2.5". Why I said get skids or a bumper ASAP.
    But I bet you just over stretched it.
    I'm not replacing mine. Lots of guys don't.
    :laugh:
  11. Mar 27, 2013 at 8:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My recomendation is to just not mess with it. Keep an eye on it. When it tears all the way around you will know it. It'll start throwing grease all over. Swap axles then.
    In the mean time, save your pennies for an autozone/o'rielly/advanced auto one and have it ready for the day you really need it.
    I think I paid $100 for one shipped to me for free no tax from advanced auto
  12. Mar 27, 2013 at 8:36 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Hmm, looks like I'm not going to bother with the boot slide mod haha
  13. Mar 27, 2013 at 8:36 PM
    BradyT88
    The whole reason the mod uses the hose clamps is because the oem clamps aren't tight enough to hold the boot in place after you slide it out.
    I see.
    I cranked mine pretty damn tight otherwise they would just slide back into place.
  14. Mar 27, 2013 at 8:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Think of it as a rust protective coating haha
    And you still have bro lean..not a ton..but some.
  15. Mar 27, 2013 at 8:41 PM
    BradyT88
    I don't think I can afford to let one of my joints go bad... Almost impossible to find spares in a junkyard and OEM's cost $500 from the dealership... And since I am locked up front I would like chew up the Autozone ones especially when I go to bigger tires... Boot kit cost me $30 from the dealership.
  16. Mar 27, 2013 at 8:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is the main problem with the Eibach coils and some of the OME coils. They give too much lift, the result is too much axle angle. As Monte pointed out, the only defense is to pull the front down with weight so the axle angles get back to a point where the boot fins wont touch.
    Unfortunately, you are going to tear boots if you do nothing and its looking like the boot slide mod is not the answer either.
  17. Mar 27, 2013 at 8:48 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah.. I'm doing a diff drop kit which I know won't do much at all. Hopefully I get lucky and get a plate bumper this summer.
  18. Mar 27, 2013 at 8:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, the true boot mod involves welding a stop on the shaft that keeps the boot from moving inward. Not relying on a clamp to do that
  19. Mar 27, 2013 at 8:52 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    The boot tear? If u look in the live thread one of mine are leaking from the same place I think, the clamp area
  20. Mar 27, 2013 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine didn't.
    I only rolled without a bumper for a month and a half.
    I do t care if I blow an axle. I know where to get two new OEM ones. Plus good reason to LT it hahaha
