Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 1, 2013 at 9:57 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I put alot of miles on the rig this time of year. Most of the sheds I've found this year are tword cle ellum and down in the blue mountains.
  2. Apr 1, 2013 at 10:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I don't know the 'blue mountains', is that like NE of cle elum? I was figuring you'd be south of I90.
  3. Apr 1, 2013 at 10:23 PM
    tacomakid96
    Phil
    Out n' about
    The blues are the mountains east of walla walla. really rugged but very beautiful scenery down there.
  4. Apr 1, 2013 at 10:46 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'd like to dedicate this post to Mark K. What upp homie.
  5. Apr 1, 2013 at 11:07 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :yay: HEY BRO! Thanks for dropping in!
    Just gettin by! Working and doing that school thing and trying to get some play time in the process.
  6. Apr 1, 2013 at 11:15 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I have no play time, only work time and sleep time. Then it's back to work time again.
  7. Apr 1, 2013 at 11:21 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    where ya workin now?
  8. Apr 2, 2013 at 1:07 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    pounding out a 4 page paper at 2 am...no big deal!
  9. Apr 2, 2013 at 1:13 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya know I have done many a late night study sessions...and to a point you are not really helping yourself IMO. If you study study study then go to bed its like you dump half what you learned out onto the pillow and forget it. Especailly if the test is the next day. You need the solid sleep more than the repetition of a few more terms to memorize. Evening before and right after dinner is when I like to study. Relaxed, focused, you can rewind afterwards that night and collect your thoughts...very dojo type shit :D
    Macro or Micro?
  10. Apr 2, 2013 at 1:24 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya, especially as you get into higher and higher div classes. Its ALL about the test grade, thats what gives you a pass or fail. If you dont truly learn it and study you are screwed.
    How do you not know if it's macro or micro lol?? Are you talking about supply and demand internationally or efficiency type stuff within a country?
    and the paper is a jazz concert report.
  11. Apr 2, 2013 at 1:33 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    ROTC cadets*
  12. Apr 2, 2013 at 1:45 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    sounds like micro economics. It's all about giving you a rounded knowledge base so you are not so single minded, same with the liberal arts classes...it's nice to experience something new and learn something sort of cool for the sake of learning it and not "when am I going to use this in my life". Because if we only learned things that directly applied to what we thought we were going to do, we would find ourselves in a whole lot of situations that we would be SOL in.
  13. Apr 2, 2013 at 1:45 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    pineapples
  14. Apr 2, 2013 at 1:49 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    wake up at 0350, ruck 10 miles
    come back
    take a shower
    go to class
    take a midterm
    wake up at 0430
    tactics lanes for 3 hours
    go to class in sweaty dirt-covered ACU w/FLC and ruck
    take a midterm
  15. Apr 2, 2013 at 1:52 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    fuck! I need to somehow come up with one more entire page to write. and I thought I had enough.
  16. Apr 2, 2013 at 1:52 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    im pretty sure im gonna be in college till im 30
    then after I get my BA I'll study for my masters till im 50
  17. Apr 2, 2013 at 2:01 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh I understand.
    is it 5 years because its really 5 years, or is it a 4 year degree that actually finishing in 4 would be nothing short of suicide.
  18. Apr 2, 2013 at 2:02 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    at my school a grand total of 9% of chemistry majors graduated in 4 years...
  19. Apr 2, 2013 at 2:06 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    done! hell yea!
  20. Apr 2, 2013 at 2:11 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yup same, if you have a real degree graduating in 4 means 16-17 credits each semster. and when your classes are freaking hard with a large workload it's just a recipe for disaster for most people. I a very easily distracted and while once I get started on home work and studying I can go on for hours...getting started and focused at a reasonable time of day is just hard for some reason. If you work, or want to have a life finish in 4 just aint going to happen. So ill take an extra year, focus a bit more on less classes each semester and enjoy the ride.
    certainly nervous about next semester...accounting 304, as my current prof. said...is one of the 2 classes that determine if you actually can get this degree. Your previous classes taught you nothing you need to know and that class will rip you to shreds...thanks for the confidence lol. It's all accounting theory haha, what shit means and how it is analyzed. Im planning on buying the text book over the summer and reading the shit out of it and taking notes so when the class comes I will be reading it a second time and already have a base of what is happening.
