Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 11, 2013 at 11:19 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I bashed my skid plates up bad on some rocks on my last truck, when I pulled them off to check them out and make sure I didnt screw anything up bad they were covered in oil! it builds up fast man
  2. Apr 11, 2013 at 11:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Changed mine only twice since I have own it :anonymous:
    But most engine oil can go 10k easy.
  3. Apr 11, 2013 at 11:24 PM
    tacomakid96
    Phil
    Out n' about
    Twice? Jesus how many miles have you put on it since you've owned frankenstein?
  4. Apr 11, 2013 at 11:27 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Good quality preventative maintenance there
  5. Apr 11, 2013 at 11:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    the trouble with not changing it, especially with dino is sludge build up.
  6. Apr 11, 2013 at 11:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Less the 20k haha..so not that bad really. As it came with fresh oil in it.
    Haha you bet haha
  7. Apr 11, 2013 at 11:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sea foam!!
  8. Apr 11, 2013 at 11:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    no wonder you only get 8 mpg
  9. Apr 11, 2013 at 11:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha well I don't drive it nice either...think that has more to do with it..
    And oil changed twice in 20k isn't that bad..
    Got new oil when I bought it.
    Then again for timing belt
    Then again..
    Not that bad.
  10. Apr 11, 2013 at 11:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    synthetic?
  11. Apr 11, 2013 at 11:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Good to hear you are using synth. was kinda wondering since you change at 3K sometimes.:eek:
    IMO synth can go longer and color is not a good indicator. What I mean is that black at 3K does not mean that the "goodness" in the oil is used up
  12. Apr 11, 2013 at 11:51 PM
    tacomakid96
    Phil
    Out n' about
    Running the same, how many miles you at ben?
  13. Apr 11, 2013 at 11:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no way man. Out of everything i have done to the truck. The roof rack made the biggest impact on highway performance. KILLED power. The folding lights help a ton though. but hands down biggest thing i have ever notice change power on the truck.
    agreed.
  14. Apr 11, 2013 at 11:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You are at 122K? :eek: You've just about caught me. :D
  15. Apr 11, 2013 at 11:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea remember it was a big deal haha passed me..
    odd i have less miles on mine yet its older..
    tho i don't drive it near as much anymore.
  16. Apr 12, 2013 at 12:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    NO! MOD THAT SHIT UP!!! :D :D
  17. Apr 12, 2013 at 12:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    seriously doubt it. In 3 years..my truck will have many a mod on it..should keep up with some SAS rigs..if things go to my plans.
  18. Apr 12, 2013 at 12:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i know i say those vids. Turbo FTW man..every time.
    i still want to turbo mine..
  19. Apr 12, 2013 at 2:47 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    within three years my truck will be flying.
  20. Apr 12, 2013 at 7:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh so your finally gonna move?
