Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 12, 2013 at 10:55 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Generally, changes to struts does not change the amount of travel. There are some exceptions tho. King, Fox, Icon, SAW/Camburg do make adjustable coilover extended travel shocks that add about a 1/2" to the overall travel. Unfortunately, it is not possible to use that extra when you are on stock control arms.
  2. Apr 12, 2013 at 11:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :mad: that doesen't make any sense lol. So the guys that get 15" of travel, its all from the control arms and the full coil over shock?
  3. Apr 12, 2013 at 11:19 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have never heard 2 people talk up such a big game completely out of their ass as you two. My god lol.
    Also I'm it like 138k...I drive quite a lot lol[/QUOTE]
    :d
    Not taking the dslr! :eek:
    A tad over stock. Which is actuall 8". Not the 6" Ben said. Mt is about 10 and LT is around 12-16
    The shock isn't really longer itself. The coils are a bit longer.
    Also 620lb coils..
    Yes e geometry gets changed in their setups with the LCAs and UCAs. But they also have longer shocks to go with them.
  4. Apr 12, 2013 at 11:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sorta right.
    Longer shocks do give more travel..
    The extended coil overs just have a 1/4" shaft spacer removed meriting about 1" more travel.
    And you only need new UCAs to use them.
  5. Apr 12, 2013 at 11:23 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you failed pretty hard at quoting there..
    but the shock is too longer, thats how it can still work with the 3" of lift without over extending. the way it sounds is the shock is functioning the same as the stock shocks did, however it is 3" taller, so what is that 3" doing?
  6. Apr 12, 2013 at 11:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No it's not. The body is the same. I do believe the shafts are a tad longer then stock. However.
    The eibachs themselves stretch the shafts out almost out all the way.
    So basically you down travel is almost already maxed out. You on have about 1-2" down travel but like 4" up travel or so
  7. Apr 12, 2013 at 11:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Reducing down travel and increasing up travel.
  8. Apr 12, 2013 at 11:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^in a nut shell
  9. Apr 12, 2013 at 11:45 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    gotcha... but since up travel is where the shock absorption happens performance (desert braaap) is increased yes? or am I backwards?
  10. Apr 12, 2013 at 11:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ...not really.
    You want lots of droop for jumping. So you shocks can starting absorbing as soon as possible.
    5100s are also valves pretty stiff for jumping. I can't air on lolo and it bounced up front pretty bad.
  11. Apr 12, 2013 at 11:48 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ok, i was thinking that as I posted that. I need to revalve my 5100s :anonymous:
    gotta make the bitches softer up top then stiffer further down
  12. Apr 12, 2013 at 11:55 AM
    Digiratus
    Roaming the PNW
    The RedHead
    5100s are not rebuildable or revalvable. That is what Icons, Kings and Foxes offer.
  13. Apr 12, 2013 at 12:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    figured so lol
  14. Apr 12, 2013 at 12:16 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well well lol. look what i found while opening up the site
  15. Apr 12, 2013 at 12:31 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    wow. just wow.
  16. Apr 12, 2013 at 12:33 PM
    BradyT88
    BradyT88 Well-Known Member
    I think you misread my post. Yes it is an S/C. I think gadget is thinking about calling it the mk4 kit. Superwerty said it is ridiculously more powerful than his trd setup and it was just running pump gas instead of meth injected. There were no temp issues with it like the trd blower either! He's pretty sure when he gets his engine built up to handle it he is.going to blow his.old times away!
    The problem with turbos is you kind of.have to.choose between instant power or big power. Not so much with the S/C if you get a big enough one.
    Yes pictars! I.am.going wheeling tomorrow too! Probably won't be many pics though since no Ben or Cameron to take them.
  17. Apr 12, 2013 at 12:39 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    WOOOOOOOO I found my MOAB videos!!!! Including my Kanes Creek Video!!!! WOOOOOOOOOOOOO
  18. Apr 12, 2013 at 12:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    haha, old thread. was from before i was a tw memeber. :rolleyes:
  19. Apr 12, 2013 at 12:59 PM
    BradyT88
    If the shocks are truly longer you can get more travel but it all depends on the setup before. My setup with the coilover out had like 10" of travel maxing out the UBJ both up and down but my shocks only allow for about 8-9" of travel so they are limiting my downtravel.
    As for in the desert yes I would think you would want about 50/50 up and down or so. You'll want the up for absorbing bumps and the down for absorbing holes. Might be a better ratio tban 50/50 but basically you need both for optimal handling. You buck when you run out of up travel and you get some body roll and such when you run out of down that usually results in hitting the bumps right after when/if the terrain starts coming back up again like in whoops.
  20. Apr 12, 2013 at 1:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laughing:
    hahaha..wow..haha
