Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 13, 2013 at 8:00 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    What if I DONT swap the ECU/electrical stuff, I'll just throw a CEL everything else will be jolly?
  2. Apr 13, 2013 at 8:00 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Wont run.
    Sell it and buy a V6 manny
  3. Apr 13, 2013 at 8:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea won't run.
    Ecu runs the auto tranny. If there is none it won't go.
    And yes full harness :eek: or I bet there is a way to splice up the two to make them work...either way a pain.
  4. Apr 13, 2013 at 8:11 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Hey Mark Im going to see Classified tonight!
  5. Apr 13, 2013 at 8:11 PM
    BradyT88
    BradyT88 Well-Known Member
    Just keep your auto. It is the superior crawling tranny anyway.
  6. Apr 13, 2013 at 8:16 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    x2
    Crawling with a standard is just annoying.
  7. Apr 13, 2013 at 8:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just cause you bitches don't know how to drive :stirthepot:
    Lower 1st gear losers :brianr:
  8. Apr 13, 2013 at 8:20 PM
    BradyT88
    :waiting for Monte to burn up his clutch: :devil:
  9. Apr 13, 2013 at 8:21 PM
    PcBuilder14
    Brent
    Nor Cal
    Hah okay!
    Go do some rock crawling and lets see how many times your truck dies! :p
  10. Apr 13, 2013 at 8:24 PM
    BradyT88
    I've killed mine a couple of times:anonymous: if autos are geared low enough you can kill them to when going right from the gas to the brake too quickly while going up hill it seems. Pretty interesting actually. Haha
  11. Apr 13, 2013 at 8:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually...I'm shocked it hasn't yet...
    I've never done that...
    f9714b60761b7b7df39ca83cc5beb50a_zps8d12_9c5c6b0997b8b6e642992c2c40982e3443f56a95.jpg
    9c461fc39ad844948078c2bc18be0873_zps1ce9_f9d4628479cc21b0f49be34b96f1ac7b1809cc88.jpg
  12. Apr 13, 2013 at 8:25 PM
    PcBuilder14
    Brent
    Nor Cal
    Oh really? Didn't know that. I killed my old Tacoma a few times when going from drive to reverse too quickly.
  13. Apr 13, 2013 at 8:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Really?? Wow. Interesting indeed.
  14. Apr 13, 2013 at 8:28 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    no good...i imagine there will be a few late season avalanches here too
    FTR: I knows how to drive!
    someone say burnt clutch?
    Uphill isn't an issue...downhill is a pain though. I'm in 1st gear, 4lo and still standing on the brake at times! :mad:
  15. Apr 13, 2013 at 8:31 PM
    BradyT88
    Yeah. If the engine is above the stall rpm and you bring it to a stop fast enough the torque converter isn't slipping so it is basically acting like an engaged clutch. And will kill the motor. Surprised me.the.first time i.did it... I've literally only done it two or three times and those are when.crawling over like a big rock or up a steep ledge.
  16. Apr 13, 2013 at 8:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lisa I think there are 2 pictures on here showing that you can't drive :D
    :p
    Don't hurt me.....:eek:
    I think I have killed my truck more coming off high revs then I have from trails or just shifting.
  17. Apr 13, 2013 at 8:34 PM
    BradyT88
    Mine runs away down hill (not any worse than a manual though really, we are.just gears higher so there is less hold back) but I have never.killed it going downhill. I think the momentum of the vehicle helps with that. Not sure why uphill helps kill the motor.
  18. Apr 13, 2013 at 8:39 PM
    MTgirl
    Weesa
    I could say the same for you :cool:
    I meant that I know how to drive a manual...
    Not talking about killing it...just when I go downhill I feel like the tranny can't keep me going slow enough.
  19. Apr 13, 2013 at 8:45 PM
    BradyT88
    Shelley wasn't the first time but I.don't think.I knew you could kill autos until that time though.
    I.can.drive manual too. My DD is a manual.
    Like I said autos typically run away because they are geared higher. If both trannies were.geared the same they would.hold back.the same. Mine holds back.well with my 4.88's. Although I.think.a.crawlbox is the only thing that holds back well enough for.actual crawling.
  20. Apr 13, 2013 at 9:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    maybe...
