Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 14, 2013 at 10:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    you guys are arguing like little school boys
  2. Apr 14, 2013 at 10:14 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Yes he did. You can see right there in the picture.
  3. Apr 14, 2013 at 10:16 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not PNW
  4. Apr 14, 2013 at 10:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    To a point it's not worth it yes. I saw Jon drag on his shackles soooooo much in lander trying hard ledges.
    Why over you shouldn't bob to much.
    Either way. Cutting your bed sides is pointless.
  5. Apr 14, 2013 at 10:21 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    H
    I
    P
    S
    T
    E
    R
    B
    E
    N
    S
    T
    R
    I
    K
    E
    S
    A
    G
    A
    I
    N!
  6. Apr 14, 2013 at 10:22 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    so where does a flat bed/no bed come in? all you are doing is eliminating sheet metal, which is what you are trying to avoid hitting in the first place. So whats the harm in cutting it.
  7. Apr 14, 2013 at 10:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You won't see me dragging my shackles at lander. will be dragging my HC bumper first. :laugh:
  8. Apr 14, 2013 at 10:25 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    die
    YOU DIDNT CUT, THERE FOR NO HC
  9. Apr 14, 2013 at 10:26 PM
    OZ-T
    Peter North
    British Columbia
    Hey get your own material Prairie boy
  10. Apr 14, 2013 at 10:27 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I think im going to bob the front of my truck. Better approach angle
  11. Apr 14, 2013 at 10:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have a hard time believing you'd cut anything on your truck..period :rolleyes:
    I'd rather drag my steel plate bumper over rocks rather then my shackles which could lead to bent leafs.
    I'm saying over bobing isn't a good thing
    I'd rather drag a bumper then shackles.
  12. Apr 14, 2013 at 10:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the PNW has prairies...
    been done before
  13. Apr 14, 2013 at 10:32 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Bullshit
  14. Apr 14, 2013 at 10:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    *therefore
  15. Apr 14, 2013 at 10:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol
    Yes it does. Cause if I start climbing a steep ledge e rear bumper sticks out further...it'll hit first.
    Actually with my swing out the Jerry can and spare tire probably would.
  16. Apr 14, 2013 at 10:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also...world championship Grand Prix is on
  17. Apr 14, 2013 at 10:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Go for it man.
    But I think it's :puke: and pointless. There is a reason why most don't do it.
  18. Apr 14, 2013 at 10:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What should my voltage at the battery be after the truck has set for a while. Lets say 12 hours. Has anyone with a meter checked theirs?
  19. Apr 14, 2013 at 11:06 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Depends on the battery. My volt meter reads 13.9-14v while running
    I can run my stereo all day and my volt meter will drop to 11v by the end of the day. Still starts perfect. If it sits all day without starting or anything, it shouldnt even drop 0.1 volt
  20. Apr 14, 2013 at 11:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Even on TTORA e land of DIY no one does it.
    I have a feeling it'll be like your valence..you'll do it...then regret it. Haha
    All you need it some tubing or something under it and it'll be fine.
    Dragging your tow hitch isn't comparable to the bedsides. That's like a 5-6" difference
    Between 12.8-11.2v
    Why your battery going bad?
