Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Apr 18, 2013 at 9:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  2. Apr 18, 2013 at 9:20 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Except back then Toyota cared enough to match the axles up well with the motor (3.4) Hence why 1st gens are better! :p
  3. Apr 18, 2013 at 9:21 PM
    BradyT88
    BradyT88 Well-Known Member
    Not really... They did exactly what they did with the 2nd gens. Took the same two rearends they have been using since the late 70's and through it under there...
  4. Apr 18, 2013 at 9:22 PM
    PcBuilder14
    Brent
    Nor Cal
    I'm ignoring your response... :D
    I'm too lazy/tired to respond...
  5. Apr 18, 2013 at 9:25 PM
    BradyT88
    This is probably the same as you guys, but the only reason I argue 2nd gens are better is cuz I own one and because really neither gen is better. Each one has it's ups and downs. There are so many of those ups and downs between the two that is really is impossible to say one is better than the other. haha
  6. Apr 18, 2013 at 9:27 PM
    PcBuilder14
    Brent
    Nor Cal
    Agreed.
    I hope to have a 2nd gen in the next 3-5 years... :anonymous:
  7. Apr 18, 2013 at 9:28 PM
    BradyT88
    :rofl: Can't deny it so chooses to ignore it:rolleyes:
  8. Apr 18, 2013 at 9:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually..I think their are more weak points in a 2nd gen..
    And having been in both many times. I still like 1sts better. Just something about the small truck to me personally.
  9. Apr 18, 2013 at 9:32 PM
    PcBuilder14
    Brent
    Nor Cal
    Great, now I've started a 1st vs 2nd war....
  10. Apr 18, 2013 at 9:33 PM
    PcBuilder14
    Brent
    Nor Cal
    True, sounds easy enough...
  11. Apr 18, 2013 at 9:46 PM
    BradyT88
    :rofl: 2nd gens aren't that much bigger than 1st gens. They just look bigger! And more plastic means less rust. We have metal only where metal is needed:D
  12. Apr 18, 2013 at 9:48 PM
    PcBuilder14
    Brent
    Nor Cal
    FTFY :D
  13. Apr 18, 2013 at 9:51 PM
    PcBuilder14
    Brent
    Nor Cal
    Knocked the roof off of the nearby school as well. The pic can't even show how much damage was done...
  14. Apr 18, 2013 at 9:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ya didn't you the vid. Was intense.
  15. Apr 18, 2013 at 9:53 PM
    PcBuilder14
    Brent
    Nor Cal
    Whaaaa...? :crazy:
  16. Apr 18, 2013 at 9:54 PM
    BradyT88
    Pssshhh!! I think you missed this discussion but we measured our rigs and Monte is wider than I am! haha Like I said 1st gens aren't that much smaller. I am a whole like 6" longer than Monte is all too and he is probably taller than me too.
    And what extra plastic do we have? The bed? haha I've seen enough pics of people hauling shit and the beds can hold more weight than the suspension can handle anyway. haha Oh and we have a plastic fuel tank.
  17. Apr 18, 2013 at 9:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The same exact rear end used with the 22R. And we all know what a power monster that one was. :rolleyes:
    :annoyed: What was toyota thinking?
    Sure its possible. 1st gen is. :)
    Thiss ^^^ :stirthepot:
    yes you have :smack:
    :cookiemonster:
  18. Apr 18, 2013 at 9:56 PM
    PcBuilder14
    Brent
    Nor Cal
    You can't compare a 2nd gen to Monte's 1st gen! He's not normal! Haha
  19. Apr 18, 2013 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea hahaha pretty much..no one has a rig like mine..1st or 2nd gen..it's just kinda...well...it's Frankenstein :D
    Amd actually on the rear end stuff. It is not the same rear end from the 70. The diff in a 70s truck is different from the 85-94 and 95-current is different as well plus there are several little oddities through out too as is custoimery of Toyota.
    On and Brady...
    Full boxed frame :cool: lol
  20. Apr 18, 2013 at 10:02 PM
    BradyT88
    He put on 12.50 tires with some wheelspacers. Who doesn't do that? haha
    Either way. Stock for stock we aren't that much bigger I think it is just the way the looks play into it. The difference just isn't like people make it sound. I pulled up next to a stock 1st gen Tundra on Tuesday and he was just as big as I was easy! Same height as me and everything! I just had more clearance underneath that him.
