Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 1, 2013 at 1:23 PM
    BradyT88
    BradyT88 Well-Known Member
    Yeah. Get an ARB twin compressor to add to my other compressor. haha. A tank is only really good if it holds enough air to fill most of your tires in one go because once the tank runs out you are filling both the tank and the tires at the same time. Since the ARB compressors shut off at 90psi you can't really fill a tank very full anyway so there is really no point in carrying a tank with ARB's. At least with the Viair's you can fill a good tank up to like 200 psi, so a small tank will go farther, but once it runs out the ARB's will beat it. 1 on 1 the ARB's have a higher output than the Viair's at least on paper anyway.
  2. May 1, 2013 at 1:25 PM
    BradyT88
  3. May 1, 2013 at 1:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  4. May 1, 2013 at 1:32 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Did Ben get robbed again?
  5. May 1, 2013 at 1:34 PM
    BradyT88
  6. May 1, 2013 at 1:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    So its a competition now to see who can air up their tires first? :rolleyes:
  7. May 1, 2013 at 1:43 PM
    BradyT88
    Of course! Who wants to wait on tires filling up. haha
  8. May 1, 2013 at 1:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea..be curious as well.
  9. May 1, 2013 at 1:57 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    actually last time i wan in Moab i dropped to 8psi and never aired back up till it was time to leave so who cares really..
    Last time i wheeled in Pocatello i didnt even bother airing down i know how to drive in this shit.
  10. May 1, 2013 at 2:05 PM
    BradyT88
    Yeah, I don't air down as much if any since I usually need all the clearance I can get around here and I hate waiting for the tires to air down and then air back up... haha If I was going to play in snow, sand or mud I will air down quite a bit though for a better ride and/or better traction and floatation.
  11. May 1, 2013 at 2:05 PM
    scocar
    scocar Patron of the Farts
    Huh, cool. I was actually wondering about this for the rare times I might encounter the need to air down in sandy areas and such on long trips on the other side of the Sierras. I was hoping I could get away with just a compressor under the hood (no ABS FTW) and no tank, but never looked into it because I'm just too busy doing other stuff, as usual.
  12. May 1, 2013 at 2:07 PM
    BradyT88
    Yep! I run my ARB with no tank just fine. I chose not to get a tank at Btnewman's recommendation. He has a little 2.5-5gal tank (can't remember exactly what size) and it is basically empty after filling up just one of his tires.
  13. May 1, 2013 at 2:10 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    FTFY
  14. May 1, 2013 at 2:12 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    k this was in live but here it is. here is the TRD rear i had ben look at. Axle and all important shit looks good, ben heard the actuator work, which is good. Now i just have to get it for cheap enough and im in business!
  15. May 1, 2013 at 2:14 PM
    scocar
  16. May 1, 2013 at 2:14 PM
    BradyT88
    :woot: Yeah I saw that in the live thread!
  17. May 1, 2013 at 2:26 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I know haha. Have to post it there to show it anywhere lol.
    Now watch me get shafted at te auction. All this planning and someone opening bid is like 800 bucks. Fuck me lol.
  18. May 1, 2013 at 2:30 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Lol you guys should have seen this thing. The passengers seat was almost where the drivers was but it hit like dead center only body/frame damage.
  19. May 1, 2013 at 2:33 PM
    BradyT88
    :pray::pray::pray:
  20. May 1, 2013 at 3:45 PM
    rctoy
    konstantenos
    Pocatello Idaho
    i saw the pics.
