Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 2, 2013 at 8:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea if an axle shaft got shoved into it..it'll be fucked.
  2. May 2, 2013 at 8:58 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    The splines should be the same as long as its the same gear ratio. What is it? 32 spline?
  3. May 2, 2013 at 8:59 PM
    BradyT88
    BradyT88 Well-Known Member
    Oh yeah! haha Is the axle even bent? It is possible to bend the housing with out bending the axle. I think that is all Jberry did when he bent his housing. If the guy continued to drive on the bent housing there could be damage to the 3rd though, but likely nothing critical unless the side gears and shift are blown up....
  4. May 2, 2013 at 9:00 PM
    BradyT88
    30 spline I think.
  5. May 2, 2013 at 9:15 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That is what ill hopefully be able to find out tomorrow. Ill see if i can go and rip the axle out and pull the third and see if the axle shaft le fucked up the third. I have lead on a couple housings ill have to call tomorrow.
  6. May 2, 2013 at 9:21 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Haha since Ben is putting out some lockrite info, i will too. I think im sold on it.
  7. May 2, 2013 at 9:22 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you guys make it seem like it's a lot of extra work...it's really not that bad. If I can do a little bit of driving and a bit of digging I can get a select-able locker for half the price of an arb and the same price as a lunch box. To me I want to select-able, so ill put in extra time to get that to happen.
    I bet my auction truck sells for more than I want tomorrow, so my next plan of action is to go move on with finding out about this bent rear and third.
  8. May 2, 2013 at 9:33 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    The thing is you havent even thought about the ecu and wiring. If you cant get it with the trd truck. The project just got a whole lot more expensive
    Rear Axle Housing – 2004 Tacoma Xcab 4x4 V6 5-speed, ABS, locking diff.
    42110-35890
    Housing Assy, RR
    $827.58
    Rear Differential Assy – complete
    4.3 locker – 95 ½ - current 4.3 ratio locking diff. (43:10 ring/pinion count)
    41110-3D280
    Carrier Assy Differential
    $1,045.94
    Gasket– Carrier to Housing, locking differential
    90301-88077
    Ring, O
    $3.66
    Rear Axle Filler/Drain plug gasket (2 required)
    12157-10010
    Gasket, Drain Plug
    $0.86
    Rear Axle housing “wheel” seals (2 required)
    90310-50006
    Seal, Type S Oil
    $5.22
    Mounting Studs - Locking Differential to Housing
    Long (2 required)
    90116-08330
    $2.06
    Medium (2 required)
    90116-A0015
    $0.97
    Regular (9 required)
    90116-08329
    $1.03
    Locking Differential Computer
    89533-35060
    Computer, 4 Wheel Drive
    $164.22
    Dash Switch – Locking Differential
    84725-35010
    Switch, Differential
    $55.39
    Differential Wiring Harness – Locking diff to frame harness, with ABS
    82127-04160
    Wire, Differential
    $129.78
    Frame Wiring Harness – Complete - From BN7 front harness connector to rear diff harness
    82164-04641
    $297.42
    Electrical Connector – Frame harness to locking diff harness
    Connector B01 female (frame wire and differential #2 wire (rear side member LH))
    90980-10931
    $8.15
    Contacts/pigtails for Connector B01 (all-weather), 7 required
    82998-12440
    Repair Splice
    $5.00
    Read this:
    http://www.toyotaoffroad.com/Articles/Projects/Factory_Locker/Factory_Locker_Install.htm
    http://www.customtacos.com/forum/showthread.php?t=119456
  9. May 2, 2013 at 9:42 PM
    BradyT88
    I'll bet he could get it to work with just some power and the switch. Hard to say though. If the locker runs on 12v he will be fine but if the ecu drops the voltage for it he might have to get really creative
  10. May 2, 2013 at 9:58 PM
    BradyT88
    So random question, but how is Mark doing? I dont recall hearing about the Rasin recently. Still have plans for truggy or rebuild?
  11. May 2, 2013 at 10:09 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Lol I think that your right on that one. And doesn't he have an auto? If he does then the lunchbox lockers drive better cause they maintain a bit of power to the wheels. I was driving my jeep at 75 through a Nebraskan rain storm and never lost traction once. Btw was in 4wd all the time and running BFG A/Ts. 45k of daily driven miles with multiple cross country trips am a FUCKED UP viscous coupler. Granted it drove better when I "converted" my jeep to 2wd but it drove fine with either.
    He can bypass the ecu an run it directly off a switch. There is a write up on T4R about it cause 4Runner guys with 01-02 runners swap them in.
    Lol I was wondering if that was going to show up here :p good review and explanation :)
  12. May 2, 2013 at 10:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you have to wire it right though, if you hook it up just to a battery and run current to it it can fuck it up.
    and i got my answer on axle shafts :mad: looks like I need a new one of these fuckers.
    well fuck, looks like I got my answer. Need new axle shafts as well.
    the 8.4 shaft is 28.25 and the 8" is 26.75
    SO...
    TRD housing
    250
    Bent TRD rear and wiring and switch (for third)
    100
    4.56 gears
    100
    rebuild kit
    50
    axle shaft
    75
    =575 for locked rear
  13. May 2, 2013 at 10:52 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Hey you forgot the $30 min for gear fluid.
  14. May 2, 2013 at 10:55 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rolleyes: whatever. just throw that on there lol
    guy in 1st gen section said he swapped his 8.4" shafts to the 8" and they are the same length and spline. so i is confused lol. fucking complicated shit
  15. May 2, 2013 at 11:15 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
  16. May 2, 2013 at 11:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hey, im pretty excited to take on a project like this! The conflicting information and constant unknowns just worry me a tad haha. I hope to god it comes into fruition like im planning! This is the kind of shit that separates the "what kind of wheels for mah lift brah" people from the more serious off roaders. If someone says it can't shouldn't be done...keep trying! Unlike my bumper, im on a mission to prove you all wrong lol.
    Thank god I have andy tho! If not id be up shit creek with a fucked up TRD axle.
    Now crossing mah fingers the third is good.
  17. May 2, 2013 at 11:26 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  18. May 3, 2013 at 12:05 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  19. May 3, 2013 at 12:21 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I would do so many things to and with jenna
  20. May 3, 2013 at 12:29 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    sounded a little rapey
    and the internet is a small place
    if she ever saw that, and took offense, i would not feel good.
    this way, theres still a chance...
