Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 3, 2013 at 10:40 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    the abs axle has a gear on it that tells the abs sensor what the wheel is doing, the different seal is set in about an inch to make room for that gear.
    here is a pic of the two
  2. May 3, 2013 at 10:47 AM
    BradyT88
    BradyT88 Well-Known Member
    I see. I'm not sure what to tell you. I imagine if the seal fits and seals it will work though, but hard to say.
  3. May 3, 2013 at 10:53 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    exactly, my only question is can i take the non abs seal (the one flush against the end of the housing) and put it in the abs axle in place of the seal that is set into the housing
  4. May 3, 2013 at 11:03 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    i think its going to come down machined depth in the axle housing, the ABS axle will more than likely be two inches further back than a non
    if that makes any sense
  5. May 3, 2013 at 11:23 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    It does. That was my question just wasn't sure how to word it. That is what I need to find out. If the housing itself is machined back
  6. May 3, 2013 at 11:27 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    looking at the first picture I see casted metal which tells me yes there is a difference in depth
    i think the guy who probably honestly knows this question the best is Jason(jberry) send him a PM, considering hes bent one of the axles before he can probably tell you
  7. May 3, 2013 at 11:37 AM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    You might not be able to. Depending on the machined surface. The surface where the axle seal sits for the non abs might not be machined in as far as the abs and the abs axles might not fit all the way in to non abs housings...the 3rds might be the same but the axle housings are probably different from abs to non.
  8. May 3, 2013 at 11:39 AM
    BradyT88
    I was hesitant to say anything about the pics since one is on the leafs and one is linked. Probably a Taco and a 4runner so they might be an accurate comparison though.
  9. May 3, 2013 at 11:43 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    ill call it as I see it, and I see the two axles have the exact same machined surface, one being x.x inches deeper, you can even lightly the see the exact same casting and spacing behind the seal on the "ABS" axle
    based on that finding, no will not work with out abs axles,
    i bet however the gears could be pressed off and use the axle sans ABS gear and the seal would than protude further past on a non abs axle
  10. May 3, 2013 at 12:07 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I guess another way of asking that is how much if that is pressed in seal and how much is machine housing
  11. May 3, 2013 at 12:12 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Go selectable man. Don't fall for the lunch box stuff. If you wheeled the truck more i would agree..but honestly..how often do you really? go selectable man.
    x2! what is The Rasin's future looking like??
    Just tell them you have an elocker and all that. Even if you have to tell them you have a 98 taco. What i do. Just so i don't have to deal with that shit.
    Probably not. Axles look WAY different.
    I don't even think you could put an ABS shaft into a non abs housing..doesn't look like it would work..
    :puke:
  12. May 3, 2013 at 12:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i like rat rods..just not a jeep..haha
    and nah. I think if he can make it work it'll be good. I dont' think unless he is 100% certain it'll work that he should get that particular E locker.
    But if he is patient more will pop up..
  13. May 3, 2013 at 12:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dont' like the first one. The turbo and exhaust is too..well..stupid..wires freaking everywhere too..
    Other one is sick tho!
  14. May 3, 2013 at 12:36 PM
    BradyT88
    Lunchbox locker! I think that is his best option next to buying an ARB. It just looks like too much could go wrong with this swap... in the end you may be $1000 deep into it just getting everything right.
  15. May 3, 2013 at 12:48 PM
    BradyT88
    Yeah. The only way I see this working well at this point is if you can find a complete TRD rearend. Then throw Jerry's 4.56's in there.
    Sorry to rain on your parade Mark. We are just trying to save you from spending more in the long run for what is potentially a worse "upgrade".
  16. May 3, 2013 at 12:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    like you couldn't hear the turbo if it was run different :rolleyes:
    still think its stupid.
  17. May 3, 2013 at 1:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. May 3, 2013 at 1:08 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
  19. May 3, 2013 at 1:16 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Brady, just picked up 2 NATO JP8/water cans for 40$!
  20. May 3, 2013 at 1:19 PM
    BradyT88
    Nice find!
