Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 4, 2013 at 2:11 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Correct. Axle shafts and housing.
    Yup. Got one shaft out. The shaft snapped off a little bit in the third but no damage there, and once we unbolted the third the other fubar shaft slid right out. Inspected everything, r and p slide smooth as butter, side gears spin opposite directions as they should, diff actuator feels tight and solid. No chipped anything no metal shavings anywhere. Feeling pretty good about it. Just gotta figure out wiring now. And get te r and p from Jerry and get it reheated. Project fuck my bank account because locker has begun.
  2. May 4, 2013 at 2:41 PM
    BradyT88
    BradyT88 Well-Known Member
  3. May 4, 2013 at 4:19 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :D
    quite exciting.
    going to have jason send the R and P, going to order the minor rebuild kit, going to get the housing and axles next week...then the rebuild begins! I don't think im forgetting anything...
    The only other "big" hurdle is going to be figuring out wiring. Have to figure out how to get the 4 wires out of the diff RR switch to the connect to the correct wires in the jumble of wires coming out of that white harness to the left, and run power to the locker. Pretty sure the locker has 6 wires...and the switch has 4 coming out of it. So i have to pour over diagrams till I understand it haha.
    also ben, the deciding factor for me against the auto locker is winter driving honestly. I don't want something that could potentially be a problem while driving in conditions that i spend a lot of time in.
    The only damage we could fine anywhere on the third. A little bit of scouring from the splines. They are only in this one spot though.
  4. May 4, 2013 at 4:48 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
  5. May 4, 2013 at 4:49 PM
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
  6. May 4, 2013 at 5:09 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  7. May 4, 2013 at 6:21 PM
    BradyT88
    You have a housing already?:eek:
  8. May 4, 2013 at 7:10 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya...kinda. there is one in lewiston (and apperntly an axle shaft) im planning on getting probably next weekend. hope to god its still there.
    edit...from le build. can i get a group prayer that the carrier bearing thing is not tweaked?
    of course andy comes in bringing debbie downer news...said if the carrier bearing things got tweaked even a thousnadths of an inch the bearing will wear prematurely and ill still be fucked. guess i need to get that checked. please dont screw this project by a thousandths of an third member, ok?
  9. May 4, 2013 at 7:22 PM
    BradyT88
  10. May 4, 2013 at 7:23 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :D
  11. May 4, 2013 at 10:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So why do you need new shafts?? Do you want ABS?
  12. May 4, 2013 at 10:06 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i am very pissed i have to go that far. but i cant find anything closer.
    im probably going with my mom lol. but ill make room for lunch. Maybe if you are that close you can even check out the axle for me and see how many shafts they have?
    Hell no i dont want abs haha, the non abs shafts wont seal properly in the 8" axle. Unless maybe I can contact marlin who made an adapter for it...ill have to look into that, maybe even join pirate to ask them since thats where I got most of the info from.
  13. May 4, 2013 at 10:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no way do all 8'' diffs have ABS..Ben doesn't have ABS..
    And lewistown..lol thats where i got my donor truck for the body swap.
    also..this is cool
    http://vimeo.com/63653873
  14. May 4, 2013 at 10:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  15. May 4, 2013 at 10:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    didnt either :notsure:
    is cool. You can make your own too. they developed software that does that. Open Source code too so you can tweak it to your liking. Pretty cool
  16. May 4, 2013 at 11:19 PM
    farmerjon
    farmerjon
    Rugged Rockies
    That is a really cool video! I love the perspectives, like that one is in a rocket that can rotate, the upside down views are cool!
    Well... one moar day, and then i have due dates off my back for a while! Two moar papers, some fitness exercises, and I'm done for a bit! Then all I have left are some classes to finish more slowly over the next few months.
    Monte: I'm still wanting to do a mod day, but have to save some money for things like the valve gasket parts and whatnot... Still need to find the right switch cover for my 3-way switch for the lights... what do you think of the below?
    The 3-way switch body: http://www.otrattw.com/products.php?cat=23
    Cover: http://www.otrattw.com/proddetail.php?prod=VVAAB00-000&cat=9 (gonna see if I can get in engraved - all the other light covers are colored, and there are already green and red lights on the rocker body.
    So tentatively, I'm thinking:
    finish Hella wiring with you teaching me wiring techniques and me asking away haha
    Wire up my secret project (remember?) - again, you teaching me... I want to know enough, that I can learn how to put a switch on my radio antenna, so that I can control when it goes up and down - that'll be the test of my knowledge haha.
    valve gasket replacement... probably spark plugs and wires while we're in there...
    and hopefully finally get my external transmission cooler on. I've had mine for a year now, almost as long as I've had the truck, but I haven't been brave enough to mess with the radiators and such...
    My goal is to get all that done this summer in time for the EPIC trip! :D
  17. May 4, 2013 at 11:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sure man I'm sure we can work something out no prob.
    Probably do two days. One fire wiring and one for the motor stuff.
    I don't really have a recommendation on covers haha
  18. May 4, 2013 at 11:54 PM
    farmerjon
    farmerjon
    Rugged Rockies
    Glad to hear you don't think this will be too complicated! I personally am looking forward to learning more about wiring and about my rig! It's gonna be fun! :cool:
    Two different days works for me.
    And you lucky dawg, you got rain all day, we didn't even get a drop! :eek:
  19. May 5, 2013 at 12:04 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Just hop down there and take a pic of the axle so I can see what it comes with and what's all on it
    Correct. Even if the truck does not have abs it still has the abs axles and the housing is still machined to fit the abs axle. It just has a plug where the abs sensor is. Basicially all trd axles have the ability for abs, but might not have the sensor
  20. May 5, 2013 at 12:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow really? Cody musta got dumped on I bet then.
    Huh odd. Well have fun with that!
