Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 17, 2012 at 12:18 PM
    #3201
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    huuwhat? the fuck is he doing here
  2. Feb 17, 2012 at 12:20 PM
    #3202
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    friday is pay day, so yes friday is awesome, i also am going to finally get my cb today, so that should be installed by the end of the weekend, sounds like a fun little project and it should give me something to do. when you guys wired in your cbs did you just tie the power wire around the accessory fuse? how did you people do it?
  3. Feb 17, 2012 at 12:30 PM
    #3203
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  4. Feb 17, 2012 at 12:42 PM
    #3204
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I need to install mine but i need to wait for my rack :pout:
  5. Feb 17, 2012 at 1:10 PM
    #3205
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This is just the place to be i guess lol :cool:
    and fuck today was so lame..just in a grumpy mood..
    getting better tho. Im thinking putting together a turbo kit for my truck..is VERY possible with the parts from my supra i have..hahaha :devil:
  6. Feb 17, 2012 at 1:14 PM
    #3206
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    :popcorn: waiting for results
  7. Feb 17, 2012 at 1:17 PM
    #3207
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its looking promising..just need to figure out about my supra injectors being compatible..find a wiring diagram for my MAFT pro..
    then..i think I'm set..haha
    just custom headers and intercooler piping..and exhaust. I already own everything else...hell maybe ill swap in my R154 tranny too..
  8. Feb 17, 2012 at 1:19 PM
    #3208
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    take your time and do it right i don't want to see a thread like this
    $*%$)@#)*@#$*))@#* I blew my engine @#$)@#$*@#)*@%
  9. Feb 17, 2012 at 1:22 PM
    #3209
    Blackdawg
    Monte
    Wyoming/St. Louis
    I won't run more then 4-6psi bro.
    So i guess ill have to buy a new waste gate..but thats not to bad.
    but i don't want to blow up the motor haha so i won't go any higher then a SC really..maybe up to 8 if I'm comfortable with it..but don't worry man. I know all about blowing up the motor stuff haha
    rebuilding a supra was handy for that at least :rolleyes: ha
  10. Feb 17, 2012 at 1:26 PM
    #3210
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I considered going turbo but i need the power down low not in the mid to hi range.
    if i went FI id go supercharger
    I hope works out man it would be sweet
  11. Feb 17, 2012 at 1:44 PM
    #3211
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually if you match a turbo correctly, you don't have that problem.
    Everyone says that, but with a smaller turbo and a tight A/R ratio, you can have boost just as fast as a SC. But Turbos are more efficient and have greater power potential so its always worth going turbo.
    Its a large mis conception that boost doesn't happen till 4k or something. But that only happens to cars with like 72mm turbos and a 1.01 A/R cause they are dyno queens.
    with a turbo like 44-67mm and a A/R of .68 or smaller, you'll get boost FAST!
    mine i sa 67 and a .58 A/R so ill probably have boost at 1200-1400 and full boost of 5psi at 2k easy.
    What??
  12. Feb 17, 2012 at 1:51 PM
    #3212
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol and what makes yours faster?
  13. Feb 17, 2012 at 2:01 PM
    #3213
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha
    meh, i have a higher top speed :p haha and am willing to bet..a bit of a crazier driver..
  14. Feb 17, 2012 at 2:06 PM
    #3214
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    My 33's bogged me down soo much
  15. Feb 17, 2012 at 2:18 PM
    #3215
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm game le go
  16. Feb 17, 2012 at 2:19 PM
    #3216
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    i have a thousand dollars that says i have a tighter turning radius than both of you
    Pay up punks
  17. Feb 17, 2012 at 2:19 PM
    #3217
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha sure man.
    and yes, same gears, and same motor, but due to the taller tires, i travel more distance per rpm..like when my speedo says 65..im actually going 69..so really..id have a higher top speed..not that top speed matters..haha
    found a sweet thread on a guy who did his own homemade rear mount turbo..works great..and was cheap..maybe ill go this route..
  18. Feb 17, 2012 at 2:21 PM
    #3218
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    just guard the turbo and oil lines last thing you need a a rock destroying everything
  19. Feb 17, 2012 at 2:23 PM
    #3219
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol i sure a shit ain't takin that bet..i have 12.5s..lol
  20. Feb 17, 2012 at 2:24 PM
    #3220
    Blackdawg
    Monte
    Wyoming/St. Louis
    Would be easy to fab up something like that tho. Plus lines would run up in the frame and be steel braided.
