Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 11, 2013 at 10:11 AM
    BradyT88
    BradyT88 Well-Known Member
    According to Tirerack the E-rated 285/75R16's weigh the same as my E-rated 255/85R16's. These tires are the same height only the 285's are about 1.3" wider. The same size KM2 is 5 lbs heavier per tire and the same size MTR is 6lbs heavier per tire, and so they aren't that heavy really. Granted we are comparing MT's to an AT. BFG's AT KO's in a D rated 285/75R16 are 2 lbs heavier per tire though.
  2. May 11, 2013 at 10:15 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    C rated FTW...:p
    jk..
    but my side wall flex better...:anonymous: lol
  3. May 11, 2013 at 10:20 AM
    BradyT88
    If you had E-rated 12.50's you probably wouldn't have any flex until you got below 10psi. haha. My E-rated skinny tires start flexing pretty good when I get below 25psi. The really squat at 15psi. haha
    The green pre-Taco I wheel with is running 12.50 general grabbers and between being really stiff and him being light The look like the are ready to run on the street at 10psi still. haha
  4. May 11, 2013 at 10:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wine squat a ton now at 12 lol
    Im hoping to go down to 6 today..we will see if i have too..
    and i bet i could flex Es. Weight almost as much as you do...haha
  5. May 11, 2013 at 10:33 AM
    BradyT88
    Yeah. You are heavy enough I'm sure.
    6psi is pretty low though without beadlocks. If you go slow you might be alright though. I have ran as low as 8, but it makes me nervous. I almost debeaded one of my tires on a rock at 18psi last time I was crawling in Shelley. haha
  6. May 11, 2013 at 10:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My rims have an extra large lip though. Designed to be run low. Unlike your :headbang: rims :p We will see..i have done 8.
    BTW..why can't i see your sig anymore??
  7. May 11, 2013 at 10:42 AM
    BradyT88
    Nice! I have no idea what kind of lip mine have, but probably not big I'll bet. I typically wheel at 18-20psi now because I need all the clearance I can get anymore it seems. haha
    You can't see my sig huh?:confused: I can still see it... Is it just a red x or does it say anything?
  8. May 11, 2013 at 10:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i usually go to 12-15. I like the ride there :p
    and yea..there is nothing there :notsure:
    just the part that is thanking Cameron for the photo..no photo tho..
  9. May 11, 2013 at 10:45 AM
    BradyT88
    Weird. I can still see it. Can anybody else see it?
  10. May 11, 2013 at 10:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there is like room under you for it..like it should be there..i just can't see it..
  11. May 11, 2013 at 10:58 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    its working fine here
  12. May 11, 2013 at 11:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol..probably..
  13. May 11, 2013 at 11:28 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    New tierods are in. wasnt that hard to put them in. waiting on alignment right now
  14. May 11, 2013 at 11:59 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I just love having to buy every little piece required for wiring since I dont have a single thing
  15. May 11, 2013 at 12:07 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    fuck fuck fuck fuck
    im getting sick, fucking head cold from hell coming on hard right now, im drugging up by if im too sick they wont let me on a plane tomorrow to go home! FUCK
  16. May 11, 2013 at 12:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol yea it is..especially if you don't plan on using it again.
  17. May 11, 2013 at 1:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    shouldn't be that hard. look up some stuff and you should be able to do it for cheap. probably just needs cleaning.
  18. May 11, 2013 at 1:53 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    MONTE! I pm'd you and need u lol!
  19. May 11, 2013 at 2:29 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I went up chinks fine when I was there last.
    I have 285s and they are E-rated. I will check the ply on my tire here henr I take a break from work.
  20. May 11, 2013 at 4:25 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    the thursday group for trifecta is going to be awesome
