Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 18, 2013 at 9:20 PM
    BradyT88
    BradyT88 Well-Known Member
    Just watched the goods and taken 2 since Boise is too boring to go explore. Both are great movies though!!
  2. May 18, 2013 at 10:20 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Alright gents here's the situation. Got the regear done, new axle is all in and driving good.
    However there is some issue with the locker enguagement. At first it would have both wheels locked in both off and on switch positions. We could hear the locker motor working the whole time. Then we took the motor out and slid the locker gear over to unlocked and locker position a few times easily. Put the motor in and when it locked it would hardly catch and we could hear the diff ratchet as we spun the tires, like it wasn't sliding the locker over enough. Also weird was that it unlocked when the switch was put in lock position.
    So something with the wiring or the locker motor .
    It locker abbé unlocked seemingly fine when it was out of the housing
  3. May 18, 2013 at 10:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wow..that's fishy man..I'd say it was in the diff if the motor works outside the diff.
    Also cody...your build can kiss my builds ass :D
  4. May 18, 2013 at 11:10 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    oh fuck you, yours is literally full of BS
    <3
  5. May 18, 2013 at 11:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol I know.
    But come on..you haven't done anything to Tiffany in the last what? 20 pages :p haha
  6. May 18, 2013 at 11:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    No the motor worked and moved what seemed to be enough when it was in the third and the third was out of the housing. We didn't take the motor out and run it by itself because we know the motor works because we can hear it. And it can't be the diff gears it self because we can lock and unlock it all just fine with a screw driver pushing on the locker gear. So either the motor isn't pushing the collar out far enough due to wiring or an internal problem, or we just didnt line up the gears right with the locker motor and the diff teeth. Not sure past that
  7. May 18, 2013 at 11:17 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    first all, Tiana.
    secondly, just wait...
    you have the RTT, I'll have the shiny
  8. May 18, 2013 at 11:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmmm..well I can't see how wiring would effect it. It's just a simple actuator and if it works it works. Or it's busted. Don't they go out every so often??
    So basically..locker doesn't work lol can you drive it?
  9. May 18, 2013 at 11:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ill have the shiney too..soon..hopefully..
  10. May 19, 2013 at 12:38 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    woot working 4x4, truck on 4 wheels, truck with no bed, truck with 89 and 89 degrees camber unsure on castor but not safely movable
    tomorrow is air locker time, and than bam bitches 37's
  11. May 19, 2013 at 1:33 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well it might not be being told to go out far enough. Dunno. And ya I can drive it just fine. Been driving back to Boise since like 10:30. Drives like it did before, slow and jumpy lol. I can lick and unlock it too, just with a screw driver
  12. May 19, 2013 at 1:34 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Also bumper is painted this week. So monte stfu
  13. May 19, 2013 at 1:52 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    sorry about the locker bro but it cant be that big of an issue at this point so dont stress. And it's all progress. Moab soon.;)
  14. May 19, 2013 at 2:00 AM
    rctoy
    konstantenos
    Pocatello Idaho
    Im the center of MY universe:D if you don't like it Find your own universe:brianr:
  15. May 19, 2013 at 2:06 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I know, hoping for an easy fix. Almost in Boise, and no grenade diff. I'd say it's good to go to Moab with.
    Dam good work!
  16. May 19, 2013 at 3:11 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    k just to include a more comprehensive summary of what is fubar
    So I got my third re geared and into the new axle and the axle under the truck and everything together snug as a bug in a rug. Just as a side note I just drove 270 miles home after we got this done so the re gear and diff are dandy.
    K so the issue. After the truck came off the lift I went to test it and no matter which position I had the locker switch in the tires would stay locked, now take note I wired and installed my own completely separate e locker circuit, but it seemingly worked fine when the third was out of the housing. The motor itself was working because every time I hit the button we could hear the actuator working.
    So we pulled the truck back in and took out the motor and slid the locker slide gear with a screw driver to unlock it and we could spin the tires in open diff mode. We then put the locker motor back in with the locker gear slid a bit differently and when I hit the switch it would slide the locker to engage but it was like it would just barely catch because we could hear the diff ratcheting trying to engage but it couldn't, because our guess is the collar did not slide enough.
    Also odd was that when I had the button depressed it disengaged the locker, and when the button was in the "off position" the locker tried to engage. Admittedly when I tested the wiring before installing I was not sure if being in or out was locked or unlocked, i just saw it move and assumed it was right. So with that, could there be a difference in how the motor works in "reverse" and "engage" mode? Like if the motor is being told to reverse when it should be locking is it spinning more or less than the locked command?
    Tomorrow i am going to test my buddy's motor in my diff to see if the motor or the wiring is the issue. We have eliminated the gears inside the diff as the issue because we were able to slide them into locked and unlocked pretty easily with a screw driver, so if there was a binding issue that could not have happened.
    Other info:
    Wiring diagram
    Testing outside the third:
    Out:
    In:
  17. May 19, 2013 at 7:57 AM
    BradyT88
    Like I sad in your build thread. Just bring a screwdriver to moab with you!:D haha
  18. May 19, 2013 at 8:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thank god
    300 miles isn't going to tell younifnthe gears are ok. Took Brady 4-5k
    Hmmm wish I could see your wiring in person. I'd be a much better help there. You could potentially have a crossed connection somewhere
  19. May 19, 2013 at 9:11 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    The way you explained it Mark or sounds like you are not dumping the voltage
    Did you install a good ground??? And like monte said check all your connections it sounds like you just applying power still
  20. May 19, 2013 at 9:21 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya, got both grounds on the bolt for the bpv
