Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 28, 2013 at 6:19 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Zero preload is when you jack up the front of the truck to full droop and back off the preload collar until the spring is fully decompressed and moves freely. Compressing that spring at full droop is "preload". The amount the truck sinks from full droop when you let it off the jack is sag. Increasing preload decreases sag. Race sag is typically 40% of total shock travel or so (60 uptravel 40 droop). Of course tuning this for the terrain and your driving style is common, and anywhere near 50/50 is good for speed. Hillbillies around here typically have 90% uptravel and 10% droop, or what I like to call redneck sag. Rides like shit but you can fit big swampers lol.
  2. May 28, 2013 at 9:11 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Ohhh fuck that is the funniest thing I have seen in a good while!
  3. May 28, 2013 at 9:34 PM
    BradyT88
    BradyT88 Well-Known Member
    Yeah I understand that, but what about taking a 16" coil and jamming it into a shock that is built for a 13" coil and not moving the collar (5100's don't have threaded collars, just 4 slots, 0", 0.75", 1.5" and 2.5"). Wouldn't that coil technically be preloaded 3"? 885's and 886's are strong enough springs to harshly slam 5100's to full extension. Hell I guess it is even worse for the actual OME shocks they were designed for because they have less travel than 5100's. 2wd's often complain of the shocks making banging noises on pots holes because they are so much lighter, and the banging noise has been determined to be the coil violently maxing out the shock.
  4. May 28, 2013 at 9:58 PM
    scocar
    scocar hypotenoper
    ta da
  5. May 28, 2013 at 10:00 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  6. May 28, 2013 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek:
    what is with the traffic going westbound from ellensburg on I-90. It came to a complete standstill. 150 miles of stop and go. Ridiculous
    Didn't get home until 11;30 last night. Ended up back tracking to Yakima and over Chinook pass. The good news was there was no traffic that way except for deer. The bad news is that at least 20 of those rodents tried to become hood ornaments. It was very nerve wracking.
  7. May 28, 2013 at 10:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
  8. May 28, 2013 at 10:17 PM
    scocar
    scocar hypotenoper
    You had it all spread out to catch water and let it flow to your tent. :mad: You want it as small as possible, preferably under the perimeter of the rainfly if at all possible. If it won't fit completely under and you need to leave a little exposed, leave it exposed on the downhill side so the water runs away.
    I am quite positive they don't even make a footprint for that awesome antique tent, but if you can find a very similar footprint for another North Face model, consider getting it. Ideally, you would actually be able to secure at least a few of its grommets under your pole tips. Ultimately, a lot smaller and easier and less crunchy...:p
    Then, stake and guy the shit out of the fly to fan away from the bottom of the tent. An inch can make a big difference. Especially if you're a virgin.:eek:
  9. May 28, 2013 at 10:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I almost died today hitting a moose in downtown anchorage haha
  10. May 28, 2013 at 10:34 PM
    scocar
    scocar hypotenoper
    LOL.
    Yes, you are right to use the grommets on the fly. Strap that shit down tight. Usually I would not use extra guy lines unless I expected lots of wind or heavy rain. And the idea is to get stuff tight so there are no (or nearly no) wrinkles in the fly. Aim for that... You generally don't' need all of them all the time, and sometimes you might need just a couple key ones to protect more vulnerable areas, depending on conditions. Go to a park and practice with them, see how it works, get all your knots practiced up, and BOYSCOUT UP!
  11. May 28, 2013 at 10:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You obviously survived. Glad to hear you are OK.
    :worthless:
    :D
  12. May 28, 2013 at 10:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have no pics :eek:
    Was running and did t have any camera. Was huge tho. I'm in my room at the slope now. Train tomorrow then work 12 hour days for the next 5-6 weeks :eek:
  13. May 28, 2013 at 10:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What time is it right now on the North Slope? 9 pm?
  14. May 28, 2013 at 11:02 PM
    scocar
    scocar hypotenoper
    Shitty job, done under duress in a massive lightning storm and hail. Not tight, not good, just wanted to get in after a tough day. Note all the wrinkles.
    Much better, note no wrinkles, only near the door flap which will go away when closed. It was very windy near this tree line pass approach.
    Same site, different angle. Had to use rocks in many cases because the soil was very shallow over a granite slab that I could not stake into. So don't take no as an answer when it comes to stakes...
  15. May 28, 2013 at 11:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    10:12 right now.
    It's 2 hours different for mountain time. Should be 1 I think for you..maybe not tho..
    Either way I'm headed to bed. Haha
  16. May 28, 2013 at 11:13 PM
    cowgirlrideon
    cowgirlrideon Well-Known Member
    Brandi
    Idaho
    06 Tacoma V6 4x4 SR5
    Brute Force front bumper, Basic camo covers interior.
    Oh no. Not scared off. Just catchin up on readin all y'all's yap some. Haha been workin a lot. Drove up near Canada today and got a load of hay. The view was awesome. May post a pic of the load and the view another time. Finish on catch up and head to bed. Got work in the mornin.
  17. May 28, 2013 at 11:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you miss more then a day..not worth catching up haha just jump in
  18. May 28, 2013 at 11:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    One hour different from me. Its 11:20 right now. And time for bed. :eek:
  19. May 28, 2013 at 11:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    An ok. Yea 5 am is so soon :eek: gonna take getting used too. I never go to bed this early haha
  20. May 28, 2013 at 11:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Have fun doing that on the wyo trip btw ;) haha
