Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 30, 2013 at 3:34 PM
    cowgirlrideon
    cowgirlrideon Well-Known Member
    Brandi
    Idaho
    06 Tacoma V6 4x4 SR5
    Brute Force front bumper, Basic camo covers interior.
    Hahahaha! Freakin love it! Sadly my younger brother is taller then I am. But I can still get him in a tousle.
  2. May 30, 2013 at 3:40 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    All I was saying is that a knock or a ping is pre-detonation which is computer controlled and that I have not ever seen that in my truck.
    I vacuum leak might (or might not) cause those symptoms too. :eek:
    A knock is a knock is a knock. A ping is a ping is a ping. If there is something rattling that sounds metallic its neither a ping or a knock.
    Yeah, I remember SLC traffic from last year, is horrible. I-5 from Everett to Tacoma is pretty much the same. Fortunately, I do not have to drive the freeways here, certainly not on a M-F workday.
  3. May 30, 2013 at 3:42 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    my MT plans are now complete :spy:
  4. May 30, 2013 at 3:42 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    :eek: what MT plans? :quickdraw:
  5. May 30, 2013 at 3:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    MT= manual transmission
  6. May 30, 2013 at 3:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Or should I say Mid Travel plans
    Sorry to get you all excited there :angrygirl:
    but seriously though you should all go to moab next year
  7. May 30, 2013 at 4:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you know how many miles on on the spark plugs?
    With time and miles, the electrode gap will widen making it more and more dificult for the arc to cross that gap. It may in fact be a missfire that sounds like a ping. This happens only under load too.
  8. May 30, 2013 at 4:31 PM
    MTgirl
    Weesa
    :cool: OIC
    I thought you were planning an invasion of the mainland starting here
  9. May 30, 2013 at 4:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    that'll be next year.
    I need to build up my army first
  10. May 30, 2013 at 4:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So you're Sunflower
    That makes sense
  11. May 30, 2013 at 4:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    you don't think..
  12. May 30, 2013 at 5:15 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Derped hard on trifecta today...backed into joe bumper and dented the tailgate and a bottle of water slipped out of my hands and cracked the windshield. Only damage...fuck me
  13. May 30, 2013 at 5:29 PM
    BradyT88
    BradyT88 Well-Known Member
    Windshields actually break pretty easily from the inside... water bottle must have been hauling ass still though. Haha nice one Mark!...
    My grandpas 83 chevy with a 5.0 in it would start pinging if you were in 4th gear (that was top gear on the manual tranny, not sure if it was 1:1 or an over drive though) and towing up a hill, even a light load like 2 4wheelers. He forewarned me that it would and told me to just downshift and it would go away.
    My understanding of the computer is it should throw a code long before you hear any pre-detetonation unless you have it really bad all at once maybe. When the computer detects it it will adjust the fuel trims once and if it detects it still it will adjust again and so on. After so many adjustments it throws a code, something like 15+ adjustments depending on the vehicle.
  14. May 30, 2013 at 5:39 PM
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    You guys know your stuff!
    Both bears are black bears. Cookies for everyone!!
  15. May 30, 2013 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    and this one ?
  16. May 30, 2013 at 6:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Spirit bear
  17. May 30, 2013 at 6:00 PM
    OZ-T
    Peter North
    British Columbia
    Be quiet
  18. May 30, 2013 at 6:00 PM
    MTgirl
    Weesa
    if that's the worst that happens at Moab I think you're all doing OK
    as much as I'm out and about I have to know these things
    spirit bear :cool:
  19. May 30, 2013 at 6:02 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I watched a documentary on my way to Japan
    Thrice
    About spirit bears
    I am expert
  20. May 30, 2013 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    It's a god damn Kermode Bear , get it straight
    And is also a black bear
