Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 10, 2013 at 8:17 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    last time i did a set of upper ball joints i just used a socket and a BFH.. ask ben he knows it was on his runner.
  2. Jun 10, 2013 at 8:19 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    We removed mine with a big socket am a BFH. Just took a lot of pounding
  3. Jun 10, 2013 at 8:22 PM
    rctoy
    konstantenos
    Pocatello Idaho
    it's like you knew i was gonna post or something.:p
  4. Jun 10, 2013 at 8:51 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Ended up picking up a $30 puller
    holyfuckingshit
    45 seconds later, BAZAM!
    im going to find and fuck whoever made this, and impacts.
    if man, ok.
  5. Jun 10, 2013 at 9:08 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Rofl!! All that hassle, then 30 bucks and 45 seconds and bam, done. You lose!
  6. Jun 10, 2013 at 10:17 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Now I just need to find out how to get the slug in the spindle haha
  7. Jun 10, 2013 at 10:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you have a propane torch? Put the unibal slug in the freezer, get it good and cold. The use the torch to warm up the spindle a bit. The frozen slug should pound in fairly easily. You might also be able to flip over that puller and "push' the slug in from below.
  8. Jun 10, 2013 at 10:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Or I can just flip that pulled upside down and thread in the bolt a little and HOLY FUCK I JUST BLEW MY OWN FUCKING MIND
  9. Jun 10, 2013 at 10:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    you sir, beat me to the punch
    great minds think alike
  10. Jun 10, 2013 at 10:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :D
  11. Jun 10, 2013 at 10:28 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    so when I popped the bj free of the arm, i had the LCA propped but not the spindle...
    and im not sure if I just drooped out the cv or if I accidentally pulled the internal out of the diff
    but I pushed it back in and propped it up now....
    Would the only way to check my stupid be to throw it into 4wd later and try see wtf happens? haha
  12. Jun 10, 2013 at 10:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you are wondering if the axle is all the way back into the diff, I think if it wasn't you would know it when you try to line up the spindle and new UCA. there is almost no extra room for the axle to move in or out.
    Is this what you are asking? Does this make sense?
  13. Jun 10, 2013 at 10:37 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Yeah, I get what you're saying- answers it perfectly
    When it fell out, the spindle was at almost a 45 degree angle away from the diff.... realized how fucking stupid I was and pushed it back in.... Though I still have movement in the spindle now.
    That's when I noticed all the air sucking/blowing out of my inner CV boot. (whistle)
    Since I have all these tools and shit now, guess my next step is to swap the CV
  14. Jun 10, 2013 at 11:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hopefully the rest of it will go smoothly. :eek:
  15. Jun 10, 2013 at 11:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Thanks for the tips :thumbsup:
  16. Jun 10, 2013 at 11:43 PM
    scocar
    scocar hypotenoper
    Finally getting some goddamn tools. :p
  17. Jun 10, 2013 at 11:48 PM
    scocar
    scocar hypotenoper
  18. Jun 10, 2013 at 11:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I just blew so much money on tools
    holy fuck
    and I still need to get a new bumper
    and my exhaust installed
    holy
    fucking
    shit
    my
    fucking
    wallet
    oh
    my
    god
    ratcheting box wrench set- $50
    puller- $35
    4x 6 ton jack stands - $120
    3 ton jack - $70
    impact wrench- $50
    pickle fork- $25
    2x C-clamps - $30
    exhaust is gonna be $250
    bumper is gonna be >500
    fuck someone give me money
    been using that, im going to PM john later thanking him for the ratcheting box wrench advice in there. haha
  19. Jun 11, 2013 at 1:03 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :eek:holeeshit
    your poor wallet. i woulda said fuck it a while ago and started borrowing tools
  20. Jun 11, 2013 at 1:13 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I always built in a huge cushion into my spendings/earnings and I guess this is where that cushion deflates haha
    those coilovers were already 1600 shipped
    arms were 500
    fuck
    there goes my plan on getting an FR-S for school. Unless my raise is more than I think
