Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 14, 2013 at 3:28 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    What shocks does Jon have, he has factory bumps an the shocks were yellow so I assumed they were wheelers. I can always get his shocks too lol
  2. Jun 14, 2013 at 3:47 PM
    lunchboxhero
    lunchboxhero Out for a rip eh!
    Aleks
    Boise, Idaho
    yeah that could work, so could "Go home Taco, you're drunk"
  3. Jun 14, 2013 at 4:57 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Remove the outter dust seal and yay a heat gun to loosen the glue. Only way I know of ad have seen some glass companies do it this way
    Basically good luck. Ben glass companies with break them to get them out sometimes
  4. Jun 14, 2013 at 6:26 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
  5. Jun 14, 2013 at 6:27 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Oh got ya. You have to pop the hole rear window out and then you can separate the framing for it and get the slider out.
  6. Jun 14, 2013 at 7:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dented mine too in Moab. Not that bad tho haha
    Just OME 9" ones I think. Or they are 8...idk. Just OME ones tho from his OME kit.
    But he just has an AAL and stock leafs. Honesty doesn't droop that much..
  7. Jun 14, 2013 at 9:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So with his shackles we will be on the same set up. The shackles will help a bit and will be good to have for the next set of leafs
  8. Jun 14, 2013 at 9:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How do they steer? :confused:
  9. Jun 14, 2013 at 10:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Its Rad and RED. I really like this Power Wagon too. I think I new someone who had one new. Its a little fuzzy.
  10. Jun 14, 2013 at 10:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I guess. But you won't gain anything..your shocks are still gonna limit you..new leafs or not. All about the shocks for droop and stuffing.
  11. Jun 14, 2013 at 10:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks like a fun day Ben.
    I just got done with work.. 15 hours..yay money...tired..
  12. Jun 14, 2013 at 10:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Totally man :cool:
  13. Jun 14, 2013 at 10:42 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Guess who's finishing his install only 5 days after she started?
    This girl!
  14. Jun 14, 2013 at 10:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Luv the videos. thanks
  15. Jun 14, 2013 at 10:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    also, sweet fuckin pics ben
    one of my cadet friends that's a E-6 has a restored bronco like that, they're awesome
  16. Jun 14, 2013 at 11:04 PM
    scocar
    scocar Patron of the Farts
    Holy crap Ben, there's a little bit of everything in that parade. Some rare looking Mopar, too. Powerwagon's badass, but powder blue...but the belle of the ball is that Pacer...bow chica bow bow!
    You really should treat yourself to a new purse after all this. Not like you have any money left to put in it though...
  17. Jun 14, 2013 at 11:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wtf..why are 5.29 gears cheaper then 4.88s??
  18. Jun 14, 2013 at 11:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You need a Vimeo or youtube account. Photo bucket sucks for video.
  19. Jun 15, 2013 at 12:37 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ANDY YOU FUCK.
    jk
    forgot my phone at my parents or something. message me on here or some shit tomorrow morning when you see this or i will be breaking down your door and comming in anyway.
  20. Jun 15, 2013 at 12:52 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    you guys
    go to the facebook tw page
    look at the guy with the painted green wheels
    Must
    not
    post
    I think i might have to ban myself from that group soon
