Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 27, 2013 at 9:15 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Why didn't you call asshole?!!!!! Not your friend any more or what? .
    Heee...sorry I couldn't help bro....but seriously. .....why no call?
  2. Jun 27, 2013 at 9:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hahahahahahaha :laugh:
    Not so good with hand tools?? Haha funny.
    You realize you'll still have to notch the square right?
    How are you notching it? Should just have to clamp it in a vice and make your marks and go to town. Shouldn't have to be 100% perfect.
  3. Jun 27, 2013 at 9:24 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ya ill have to notch it but a lot less. Only where it connects to the round bar. The rest of it is just basic straight cuts at an angle.
    Believe me I tried to notch them every way I could with the tools I had. For the amount of time it took and the way it looks it's not worth it
  4. Jun 27, 2013 at 9:25 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Hmmm notching isn't that hard bud. But you should look up some notching stuff on how to do it. And your still going to have to notch square tube.
    So picture of the other side??
  5. Jun 27, 2013 at 9:37 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Sunce you guys are so good at this can you explain how I'm supposed to do it?
  6. Jun 27, 2013 at 9:40 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  7. Jun 27, 2013 at 9:41 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Would be great to have, but not at this time sadly. Just getting some square tubing
  8. Jun 27, 2013 at 9:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Draw it out on the tube man. Both ends so you know it'll be strait.
    I'd use a cut off wheel or sawzall to cut a few notches down to the line I drew. Which should be simple to figure out how deep .75-1" would work for the deepest point.
    Then just grind out an arc..I don't see what's so hard??? :notsure:
  9. Jun 27, 2013 at 9:43 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Try this- http://www.metalgeek.com/static/cope.pcgi
    Just print it out and cut out the pattern, then take a sharpie to the pattern on the tube. Cut along the dotted line.
  10. Jun 27, 2013 at 9:46 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Did that. Still didnt work right. There was too much gap. I don't have every tool under the sun either.
  11. Jun 27, 2013 at 9:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So you ground out too much. Just grind and test till you get good at it?? Idk..what I do for a ton of stuff. They you'll just dial in how much to do...
    But I'm coming from a woodworking back ground so I'm used to stuff taking a long time and using a ton if hand tools...:eek:
  12. Jun 27, 2013 at 9:54 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    That's part of the problem. If I have to grind down and test fit each one 10 times for 25 notches it would take a week. By using square ill notch it like 8 times
  13. Jun 27, 2013 at 9:56 PM
    BradyT88
    BradyT88 Well-Known Member
    Just invite Andy over Mark!
  14. Jun 27, 2013 at 9:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So he can do what? Hit the pipe with a hammer till it notches itself. Plus he's busy
  15. Jun 27, 2013 at 9:59 PM
    BradyT88
    Yeah and everything will fit the first time :p
  16. Jun 27, 2013 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No if you do it with the first one. You learn how much to grind. Repetitions make it go faster. .
  17. Jun 27, 2013 at 10:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    This kind of conversation sounds familiar
  18. Jun 27, 2013 at 10:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Ben's fence wins
  19. Jun 27, 2013 at 10:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Jun 27, 2013 at 10:08 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh I'm not done yet. Round 2
