Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 27, 2013 at 10:09 PM
    scocar
    scocar hypotenoper
    Dear god the gay.
  2. Jun 27, 2013 at 10:10 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    You really put it as your sig already? Jesus
  3. Jun 27, 2013 at 10:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You ha e failed us all mark..:pout:
  4. Jun 27, 2013 at 10:14 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh come on mate!
  5. Jun 27, 2013 at 10:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Stfu amir
    Nobody likes you
  6. Jun 27, 2013 at 10:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Redemption...must..be..yours..
  7. Jun 27, 2013 at 10:24 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    It will be haha
  8. Jun 27, 2013 at 10:27 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Um well use the cut off diagram posted or you can cut two 45 deg cuts. Plus your building a rack bud, Not a roll cage. Just fill the gaps and grind smooth. Your over thinking this and you can get a tube mother from harbor freight for like 30-50 bucks or something like that.
  9. Jun 27, 2013 at 11:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Speaking as one born and raised catholic... I am still recovering. And its been a looooooong time since I got away from that crap. That shit fucks your head up.
    My advice is, if you don't feel you can jump thru their hoops, then don't. Do what you want to do because you want to.
    Ben, click the apple symbol in the upper left corner of you desktop. From the menu, select About this Mac. What does it read? OS X 10.x.x?? Does the CPU line say Intel in it?
  10. Jun 27, 2013 at 11:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I still vote PJs...
    I'm episcopalian..:p
    Tho ill admit I haven't been attending regularly for years. Only to play trumpet really..haha
  11. Jun 27, 2013 at 11:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your computer is out if date..
    Mine is 10.7.7 I think..
  12. Jun 27, 2013 at 11:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not that old. You said 4 or 5 years old.
    Is possible to upgrade it to 10.7, Lion, or even 10.8, Mountain Lion but shouldn't be necessary. And 4 GB of RAM should be plenty for most situations.
    When was the last time you did a simple reboot. You told me you never shut your Mac down. A reboot will release all the items currently using RAM addresses. Your slowness could be all system functions are using a page file to store temp data. Page file is slow, uses hard drive space.
  13. Jun 27, 2013 at 11:51 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Ha ha I am running the exact same model as you are. Bought it back in early 2009. I do a full wipe on the hard drive every so often. Takes a while to do but it helps clean it up. All my stuff is backed up on my external so it is just apps to install. Mine is starting to act weird too and probably gonna end up reinstalling again soon
  14. Jun 27, 2013 at 11:54 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I was going to upgrade to 10.7 but I guess it doesn't run very smooth on the model I have. Might give it a go though. I guess 10.9 Mavericks is suppose to e pretty sweet though. Might just up to that but then I have to install 10.7 and 10.8. Dam Apple!!! It I a love hate relationship
  15. Jun 28, 2013 at 12:10 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :eek: They are calling the next one Mavericks? What?? No feline theme??
  16. Jun 28, 2013 at 12:17 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Get yourself one of these. They are awesome. I have several 500GB 7200 Seagate HHDs. I'll give you one to put into the enclosue.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817173042
    This is what I do for backup. When the drive gets full of photos, just swap out the drive.
  17. Jun 28, 2013 at 12:40 AM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Yep Tim Cook is messing it all up. We never got any of the good ones like sphinx or Bengal. Hell I would have guessed this one was gonna be called "Feral" lol
  18. Jun 28, 2013 at 12:53 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I have a 1tb
    ccleaner does wonders
  19. Jun 28, 2013 at 6:14 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Mark. One suggestion from me. Get some flap discs. You're never gonna make anything that looks good using grinding wheels.
  20. Jun 28, 2013 at 6:55 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Mark another idea for notching!!! Get everything cut to length and go visit a shop, ive done that in the past and works out pretty cheap and usually much faster only an hours labor for them at most as well
