Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 6, 2013 at 2:00 AM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Two types of stuttering. There is popping where you have too much wore speed and too low of voltage causing the arc to be really short. Second is wire is too slow and the voltage is high causing the arc to be long and thus melting the wire before it has a chance to make it to the puddle. It is finding that happy medium. Then it is adjusting it to get the proper penetration for the metal you using.
  2. Jul 6, 2013 at 2:01 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i just need a solid wire and a gas welder! problem solved
  3. Jul 6, 2013 at 2:02 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ben you werent my friend on fb? WTF?
    also. this photo is bad ass!!!!
  4. Jul 6, 2013 at 2:05 AM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    That was a vertical weld going down. And stacked dimes is a TIG thing. Mig can look like it but it also varies from machine to machine also the angle your work at
  5. Jul 6, 2013 at 2:06 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    why would you weld down :confused:
    you vert weld up
  6. Jul 6, 2013 at 6:45 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    1) unplug machine
    2) Open side case up
    3)unscrew the bolt holding the leads on, and reverse them
    4)weld mostly spatter free.
    This is common practice in the flux core world. I'll bet you a beer your manual even advises it.
  7. Jul 6, 2013 at 6:57 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Hmm. Might have been good to know lol
  8. Jul 6, 2013 at 7:40 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Ugh the wife really needs to learn proper vehicle care. I got in it this morning and just about puked, leather seats have crumbs all over, carpets are sticky, and the exterior had three layers are dirt and grime...... going to be a long day working on her car
    Pisses me off she has a 40k car and she treats out like a 5k car
  9. Jul 6, 2013 at 7:58 AM
    BradyT88
    BradyT88 Well-Known Member
    All depends on how they are designed. I have 450 watts RMS driving my two 12's and they hit hard, yet there are some top end 8's out there that my amp wouldn't even budge. My guess is that alpine you bought requires more watts to drive than what you currently have. My 12's are a little under powered due to my car's alternator not being able to keep up and it causes them to fade a little on loud hits and they respond a little slower, but it's hardly noticable. I get 2-3 volts drops on hard hits, but it's still not enough to cause the headlights to dim so no biggie.
    My interior is thrashed right now... I keep going and playing in the dunes so I don't bother cleaning it out. It's pretty damn dusty...
  10. Jul 6, 2013 at 8:15 AM
    BradyT88
    Morrison Jeep Trail preview... :p
  11. Jul 6, 2013 at 8:19 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Brady it just upsets me that she has a car a lot of people would drool over for a daily driver and she just treats it like shit
  12. Jul 6, 2013 at 9:45 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    A type R sub is a 500w rms sub. Your amp wired in a single channel is like 112w rms and bridged w as like 200somthing.
    Wayyyyyyy under powered man you'd way a 6-900w rms amp for a type r to hit awesome and sound good.
    I already explained this too you...haha weren't you listening :eek:
    :rofl:
  13. Jul 6, 2013 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It won't. What I told you.
    And did you have the amp bridged? Was it 2 or 4 ohm?
  14. Jul 6, 2013 at 10:29 AM
    BradyT88
    Monte's nailing all the questions on the head.
  15. Jul 6, 2013 at 12:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dual VC? Or single?
  16. Jul 6, 2013 at 12:22 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Mark your lil 4cyl truck does give me inspiration to actually try and do cool stuff with mine lol
    I went wheeling with ben and between his lift and locker he made it look ez pz lol
  17. Jul 6, 2013 at 12:29 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    If you want 4banger inspiration...just look at pepe/infernals truck truck
    Sweeeeeet jeebuz
  18. Jul 6, 2013 at 12:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :D it does pretty well. And if Ben makes it look easy...I need to go haha.
    Dude pepes truck is literally my inspiration for how I want mine done. D60/70 5" leafs (all pro I think), 42s. that's what I want
    I know he's linked now, but I'm not getting into that
  19. Jul 6, 2013 at 12:47 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    wtf ipad
    truck truck?
  20. Jul 6, 2013 at 1:54 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    You can go do either buddy. On rid just slightly and I mean slightly stronger than the other. That so coming from a welder.
