Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 16, 2013 at 6:18 PM
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    :mad: :mad: :mad:
  2. Jul 16, 2013 at 7:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Jul 16, 2013 at 7:22 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    4xinnovations. Same as Ben.
    I really wanted some Relentless fab kickup sliders, but being about $400 more and a 3-5 month wait I couldn't justify it. I really need sliders now. I don't think I'll regret it once I get them installed haha
  4. Jul 16, 2013 at 7:53 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  5. Jul 16, 2013 at 8:10 PM
    BradyT88
    BradyT88 Well-Known Member
    you can thing of 20 better things than outrunning Monte and Ben?:p haha
  6. Jul 16, 2013 at 8:11 PM
    PcBuilder14
    Brent
    Nor Cal
    I think he can still outrun Monte... Haha
  7. Jul 16, 2013 at 8:12 PM
    BradyT88
    They raced once. I think it was a tie... haha
  8. Jul 16, 2013 at 8:13 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no i certainly lost. bad
    might tie now
    if anything my latest wheeling trip showed me i needed lower gears...
  9. Jul 16, 2013 at 8:33 PM
    BradyT88
    Really? Not enough power or what? Autos usually don't have gearing problems...
    When I climbed this obstacle in this direction I was having to give it more throttle than usual and thought it was odd and after I finished I realized I did the whole thing in 4Hi. Truck did it pretty much no different than if I had been in 4Lo, I just had to use a tad more throttle to get the truck to move.
    Caleb on the other hand has a V6 auto with factory 4.10's and would have power issues on some obstacles. He would floor it and just not move. Just flat out didn't have enough power to turn those 34's.
  10. Jul 16, 2013 at 8:35 PM
    PcBuilder14
    Brent
    Nor Cal
    I was in 4hi at one point trying to climb a rock and it wouldn't budge. Put it in 4lo and it practically crawled over by itself.
  11. Jul 16, 2013 at 8:35 PM
    BradyT88
    Also, your auto has a really high geared 1st gear, in case you haven't caught that conversation. A factory 2nd gen with 3.73's diffs and 1st gen manual with 4.10's is lowered geared than Silas with his 5.29's when all are in 4Lo and 1st gear.
  12. Jul 16, 2013 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I won :p was up a hill tho..and wasn't loaded with gear..or rear bumper..or winch..or skids..
    Come on..be awesome!!
    Offer 900
  13. Jul 16, 2013 at 9:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I know I'm a little late to this discussion but...
    I was surprised by how much the sidewall deflects at 20 psi. It feels and looks like 15 psi on my previous set of KMs. I did go down to 15 this last time wheeling with Mark's dad and the jeeper guys. It was really slow sloppy gooey mud. slick as snot. 15 felt too low actually and the two front tires got wood wedged into the bead. First time that has happened in a long time and never with these tires. I'm thinking it was because I was at 15.
    Bottom line is the skinny KM2s don't need to be aired as far down as the fat KM2s to get the same effect where the sidewalls collapse and the conform to the shape of the rocks and tree roots.
  14. Jul 16, 2013 at 10:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cause we already float :cool:
  15. Jul 16, 2013 at 10:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Like a butterfly?
    ...and sting like a bee?
  16. Jul 16, 2013 at 10:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Exactly :cool:
  17. Jul 16, 2013 at 10:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have a confession to make. I lied the other day when I saind the truck was all ready for the epic.
    It wasn't. I had to work on it again today. :D
  18. Jul 16, 2013 at 10:43 PM
    farmerjon
    farmerjon
    Rugged Rockies
    what'd you do??
    I'm so happy, I got an 80% on the chapter 9 test (out of 14 chapters - together, they make the total precalc class grade), which is awesome, considering all the stuff I could have gotten wrong, in the past... Just need to get my daily quota closer to done....
  19. Jul 16, 2013 at 10:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your truck needs a name..
    And oh ya??? What?!
  20. Jul 16, 2013 at 11:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Put the rear mudflaps back on. Mostly to keep the law off my back on the cross country drive.
    It does have a name... I call it Ginger Turd :laugh:
