Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 17, 2013 at 10:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Seems like an OEM toyota clutch might be a better option. How does the price compare to the marlin kit?
  2. Jul 17, 2013 at 10:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    What?? 3k with 4.88s???
    Very..
    They use a Toyota clutch. Well and Seco and asin pressure plate. Supposed to be better.
    Not sure what a full OEM kit is. Marlin is 300 before shipping.
  3. Jul 17, 2013 at 10:44 PM
    BradyT88
    BradyT88 Well-Known Member
    If you are running 4.88's and 35's, you will run just north of 2950 rpm at 75 mph.
  4. Jul 17, 2013 at 10:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got 2800..which is what I'm at now pretty much..
  5. Jul 17, 2013 at 11:05 PM
    BradyT88
    4.56's would be 2750rpm. The calculator gets 4.88's are 2950. Says you should be at about 2650 right now.... Factory tires would put you at about 2800 rpm though.
    http://www.grimmjeeper.com/gears.html
  6. Jul 17, 2013 at 11:13 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I know!! I was just looking at it today. My clutch is pretty much toast. I called them and they said 2-3 weeks
  7. Jul 17, 2013 at 11:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting.
    I'm still doing 4.88s haha Jon wasn't impressed with 5.29s
    Fffuuuuuuuuucccckkkkkkk
  8. Jul 17, 2013 at 11:16 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    They make a Heavy Duty 1,200lb clutch kit that has 33% higher load rating than stock.
    Marlin Crawler pressure plate: 1,200 ft-lb
    OEM: 900 ft-lb
  9. Jul 17, 2013 at 11:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Which is what I want for the 35s..
    Crap..should ordered it last week.
  10. Jul 17, 2013 at 11:21 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I'm running one of those :D
  11. Jul 17, 2013 at 11:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Send it to me :p
  12. Jul 17, 2013 at 11:22 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    TG has a 1,600lb clutch kit. 01Tac0ma (Chad) just recently put one in. Hes pretty happy with it
  13. Jul 17, 2013 at 11:24 PM
    flatblack
    CDA
  14. Jul 17, 2013 at 11:27 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  15. Jul 17, 2013 at 11:28 PM
    flatblack
    CDA
    oh, if you didn't know
    The Marlin Crawler Clutch kits are all OEM except the higher-rated pressure plates
  16. Jul 17, 2013 at 11:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I see no clutch kit..
    Do see a power steering kit I'd like too..
  17. Jul 17, 2013 at 11:28 PM
    flatblack
    CDA
    Let me know (either of you)
    We'll work something out
  18. Jul 17, 2013 at 11:31 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    http://www.trail-gear.com/brakes
    Bottom of page. Here is the part# for the ceramic kit: 100043-1-KIT
  19. Jul 17, 2013 at 11:31 PM
    flatblack
    CDA
    Oh, by the way
    All the clutch parts I have in the closet are OEM
  20. Jul 17, 2013 at 11:32 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Wait, so what exactly do you have? Cause i want the HD pressure plate
