Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Feb 24, 2012 at 9:16 PM
    #3781
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  2. Feb 24, 2012 at 9:20 PM
    #3782
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Did it even turn over at all?
  3. Feb 24, 2012 at 9:36 PM
    #3783
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    the starter should still make some sort of noise even if its bad i believe.
  4. Feb 24, 2012 at 9:38 PM
    #3784
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i dont think you need to turn the key on at a precise time, just as long as its in the on position you should be good to bump it
  5. Feb 24, 2012 at 9:39 PM
    #3785
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yeah pop the clutch while you start it. If its the starter it should still want to start. Get someone to tap thr starter with a hammer while you turn the key.
  6. Feb 24, 2012 at 9:40 PM
    #3786
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    sounds a hell of alot like what my truck was doing a while back, minus the initial loud noise.
    does the starter give you a single loud click every time you turn the key for ignition? if so position the jump cables on the battery on the back of the battery clamps, and just turn the key over and over until it fires. might take 3 tries or 12. if it starts EVENTUALLY you are looking at a new starter
  7. Feb 24, 2012 at 9:51 PM
    #3787
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You have to hit the starter with something hard though cause you.gotta.get those contacts to touch
  8. Feb 24, 2012 at 9:55 PM
    #3788
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Starters usually go slowly so I think this isnt the problem.
  9. Feb 24, 2012 at 10:01 PM
    #3789
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    GOD! for the lift of me i cant get my sig pic to just be the right size:mad:
    WOOHOO FINALLY
  10. Feb 24, 2012 at 10:11 PM
    #3790
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what haha? wait the mini van? oh for sure. we r hittin up boise ridge road once brother john gets the TG front bumper and the OBA for his 215s on 14" steelies
  11. Feb 24, 2012 at 10:20 PM
    #3791
    jordando89
    jordando89 Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
    hey guys my names jordan I'm from deary, Idaho small town by moscow, idaho anyone close by?
  12. Feb 24, 2012 at 10:23 PM
    #3792
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya, pretty much everyone except me chris and JW...seriously why is everyone from this state NOT from the major population center:mad:
    :rofl:
  13. Feb 24, 2012 at 10:24 PM
    #3793
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Its the "pop" noise you describe that bothers me... A pop or a bang?
    could be the batt. You said you have 1 or 2 volts...really? Seems like it would be absolute zero or 10 volts. Nothing in between.
    If it is in fact zero volts, check the ground connections, one between the chassis and the engine block.
    Any unusual smell, burned epoxy?
  14. Feb 24, 2012 at 10:25 PM
    #3794
    jordando89
    jordan
    idaho
    yep spud hill
  15. Feb 24, 2012 at 10:31 PM
    #3795
    Digiratus
    Roaming the PNW
    The RedHead
    Not if the bang/pop was two plates coming in contact with each other.
    Other bang noise possibilities are more worrisome. It would eliminate some if the engine actually turns over some, even if it doesn't start. :eek:
  16. Feb 24, 2012 at 10:37 PM
    #3796
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :burnrubber::headbang:
    sweet! alive as in just enough to get it home or alive as in problem fixed?
  17. Feb 24, 2012 at 10:44 PM
    #3797
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    That "pop" noise was your probly your battery cable making contact with something. The weather could have something to do with it, especially all that moisture.
    I had a similar issue one morning where i turned the key and nothing. Kept turning it and just before i gave up it started.
  18. Feb 24, 2012 at 10:49 PM
    #3798
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm glad it started. you don't need a tow truck.
  19. Feb 24, 2012 at 10:50 PM
    #3799
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    the truck was just getting even with you for abandoning it in the snow :devil:
  20. Feb 24, 2012 at 11:04 PM
    #3800
    Digiratus
    Roaming the PNW
    The RedHead
    :thumbsup:
