Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 23, 2013 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The bilsteins are a standby fix so I can do an AAL or extended shackles or both. Also thinking about shock relocation.
    I think I need to learn to weld. :eek:
    The wheelers alcan 8-leaf springs give about 2.25" of lift, empty bed. YMMV
  2. Jul 23, 2013 at 10:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get a welder and start. Not super hard.
    How long are they? 10"
    I'd do both really. Shackles for droop and AAL for weight capacity.
  3. Jul 23, 2013 at 10:33 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    True true lol
    The one reason I love my linked rear end. I have some more things I am going to be dpi g to get some more flex, but I am going to run into the issue of coils length
  4. Jul 23, 2013 at 10:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The 5125s are 9.5" travel.
    Shackles are an easy swap. Probably start there and see what I get. Definitely don't want your stink bug look. :D But a slight rake when empty would be OK. And if the Foxes still work in the stock location, ... sweet.
  5. Jul 23, 2013 at 10:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The foxes will work with a 1" lift shackle..but you won't gain any gains in droop without longer shocks.
  6. Jul 23, 2013 at 10:44 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Well points for ingenuity. Buddy of mine found a use for the stock bottle jack.
  7. Jul 23, 2013 at 10:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would definitely flex it out with the forklift again just to see what is what. Last time I did I could almost get to the bumps and there was an inch of up travel left in the foxes. I'm guessing that using the forklift I can now probably get there.
    Also, saw this in another thread and really did laugh out loud.
  8. Jul 23, 2013 at 11:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    what do you guys think, about me running stock shackles but swapping to wheel?
    I have my AP shackles sitting there......but i dont need more rake..
  9. Jul 23, 2013 at 11:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's sketchy as fuck. I'd never do that
    Compress to the bumps? I'd hope so..I'm talking droop though.
    Horrible idea. Snapping shackles ain't a walk in the park.
    Think about it. When the truck is just sitting there the leafs are slightly compressed and the shackles are at around 45* with out the shackles the leafs curl back up. Yu have to pull the leafs back down to get them to line up with eh shackles. It's a bitch. Takes an hour.
    Not a good idea.
  10. Jul 23, 2013 at 11:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also..I fly home tomorrow..well..Thursday..sorta..morning..whatever. I'm leaving here! Get to drive the FRV home :cool:
    And I think I have a name for my dbl cab..
    The FSV..
  11. Jul 23, 2013 at 11:32 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    back when I was testing my expo clearance... I swapped em on and off twice, only took 15 mins each side
    maybe I was just lucky...
  12. Jul 24, 2013 at 12:28 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    waste of time dude
  13. Jul 24, 2013 at 12:34 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    but theyre shiny :(
    just give too much lift as is
    might get a set of toytecs
  14. Jul 24, 2013 at 12:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why would toytechs be any different lol shackles are shackles..
  15. Jul 24, 2013 at 12:35 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    theyre stock length/replacement greaseables
  16. Jul 24, 2013 at 12:36 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    so no more sex bed suspension
  17. Jul 24, 2013 at 12:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Those are OME. Toytechs aren't grease able. Mine arent.
    You just need some weight to justify the lift.
  18. Jul 24, 2013 at 12:41 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    O. OME's then. haha
    yeah I do. I haul heavy, but in the meantime... haha
  19. Jul 24, 2013 at 12:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Fat drunk girls you pick up passed out on the beach don't count cody. I don't care if it's every night.
  20. Jul 24, 2013 at 12:47 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    JUST BECAUSE I DONT HAVE A RTT AND DONT HAVE A GIANT VAGINAS WORTH OF LIGHTS
