Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Aug 17, 2013 at 9:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It ain't worse then that..I know,,cause I did both..in a week :p haha
    Cool photo man!
    Also welcome to the good thread :cool:
  2. Aug 17, 2013 at 10:51 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thank god mike had extra lbj bolts
  3. Aug 17, 2013 at 11:03 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
  4. Aug 17, 2013 at 11:05 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Oh my GOSH, that's freaking awesome
    where is this?
    EDIT: upon a closer look, this appears to be a photoshop, huh?
  5. Aug 17, 2013 at 11:05 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Hmm, what size bolts are the LBJ bolts. May be good to carry extras...
  6. Aug 17, 2013 at 11:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :thumbsup: Get some for your OSK
    And a small tube of red loctite
  7. Aug 17, 2013 at 11:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I didn't realize you were in SLC. Went thru there last evening. Stayed in Ogden last night.
  8. Aug 17, 2013 at 11:58 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Well I am in provo actually. About 35 miles south of SLC. Lol I am hoping to make the run next year hopefully. Should be set up good enough to go then.
  9. Aug 18, 2013 at 3:17 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well, you went through provo, slc then ogden. so slc was actually only a third of it. it all just morphs together :p
    ben made it safely to boise, and i was able to convince him to hang out with us for a bit before and crashing at his friends house.
  10. Aug 18, 2013 at 8:08 AM
    BradyT88
    BradyT88 Well-Known Member
    Ben, I was already in bed by the time you texted me (I've been going to bed at 9 and getting up at 5 for the last couple weeks or so...) but if you went from SLC to Boise, why did you go thru Poky? It would have saved you at least an hour if you took I-84 at Tremonton instead of staying on I-15...
  11. Aug 18, 2013 at 1:19 PM
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Probably a little more than that cause it is at least a 2 hr divert to go through poky.
  12. Aug 18, 2013 at 1:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    A 2 hour drive just to get thru SLC metro. Its incredible how big that place has gotten. 114 miles from spanish forks to ogden. One continuous city almost. Bumper to bumper traffic at 70 mph at 5:00 pm on a friday. With a few slowdowns thrown in. Reminded me of L.A.
  13. Aug 18, 2013 at 3:20 PM
    BradyT88
    According to google it is only a 50 minute difference. Surprised me because I thought it would be much larger as well.
    So Ben what's with the new tire being a KO instead of a KM2?
  14. Aug 18, 2013 at 4:01 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Hey dudes, made it back as well. Feeling a bit sik gnar though
  15. Aug 18, 2013 at 7:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It does but most seem to ignore it. Including the highway patrol. :eek:
    I was coming down the pass about 10 miles before la grande on I-84 doing ~72-73, was passed by a BMW that had to be doing 90. We came around a bend with two parked PDs right there... They ignored both of us. :notsure:
    Whatcha doing in Oregon? :popcorn:
  16. Aug 18, 2013 at 7:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ya wth are you in oregon??
  17. Aug 18, 2013 at 8:09 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    ugh had to add up receipts...... scary stuff
  18. Aug 18, 2013 at 8:14 PM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Haaa!. Love the pic Ben!. So I guess I was part of the met then..:D.. I shall dub it the lesser Wy/Mt/Co/boi front hard meet!
    Nice to finaly meet you Ben! Had a great time talking to you. We will ask have to meet Up again soon! .
    Mike the tripod is awesome! Let's work something out and we will make plans and such!
    Thankyou!:thumbsup:
  19. Aug 18, 2013 at 8:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    stfu and gtfo mr money bags
    ya wish you could have made it! although we decided it was rather good you didn't do the switchbacks on morrison..ha
  20. Aug 18, 2013 at 8:32 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    yes mr money bags has to restart, and its not as easy as some would expect to pile 20k into a rig to get it where the other was ;)
