Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Aug 19, 2013 at 5:05 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Started that Yamaha 426 and rode it a little bit, there's a lot of power there! Need to get a lot more practice!
  2. Aug 19, 2013 at 10:05 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    those are great bikes! actually have a higher top end than the 450s
  3. Aug 19, 2013 at 10:08 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    so about those tires...
  4. Aug 19, 2013 at 10:27 PM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    I think we may end up gearing it lower just for our putting around on the farm or trail riding... people we telling me how much they had them because they couldn't get them started after flooding them... oh well, all a learning experience for me!
  5. Aug 19, 2013 at 10:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    if you do a valve adjustment every year or so it will start up on the first 3 kicks every time. Just have to do some work on them.
    And i dont see a reason to waste the money to gear it down :confused: just learn the feel of it and put around in 1st. no biggie.
  6. Aug 19, 2013 at 11:42 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I say again.....Damn I look good
  7. Aug 20, 2013 at 5:29 AM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    The valves were adjusted this spring, its just tricky to learn the compression release lever while kicking it but I got it started after 5 kicks of ever being on that bike. And its a racing bike with 13/49 sprockets and I plan to put on at least 12/52 so I can putt up a rutty trail rather than riding the clutch at all
  8. Aug 20, 2013 at 7:46 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Stock it had 14/49. Most trail guys run a 14/52. Take the number of teeth on the back sprocket and divide by the number of the front.
    Example: 48 div by 14 = 3.43 good top end or 52 div by 13 = 4.00 good bottom end. If you want a happy medium try 14 and 52 = 3.71 and so on.
    the front turns 3.71 times to 1 turn of the back, this is your gear ratio.
    the higher the ratio the lower the gear = bottom end torq
    the lower the ratio the higher the gear = top end speed
    Just dont try a 12 on front, even a narrow(cheap) chain scrubs the case.Requires spacers which offset chain which = more wear.
  9. Aug 20, 2013 at 8:33 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well fuck me
  10. Aug 20, 2013 at 8:46 AM
    BradyT88
    BradyT88 Well-Known Member
    You want his 37's? haha
    Is that the roof of a caged rig?
  11. Aug 20, 2013 at 8:51 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Vultures man I tell yah vultures, too bad I need the rims and tires for the next project ;) Its like everyone just automatically assumes i won't need bad ass tires for my next rig
    do people really think the next one wont be huge???!!!
  12. Aug 20, 2013 at 9:05 AM
    BradyT88
    I'm pretty sure you won't need 37's for the next rig unless it is another 2nd gen. Pretty sure you'll want some 42's or something:rolleyes: haha
    My question is, what the hell is Mark going to do with 37's? haha other than buy a new cv every other week:p
    Now about that crawlbox you have ;)
  13. Aug 20, 2013 at 9:26 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Mind blown
    Nothing is up for grabs yet wow!
  14. Aug 20, 2013 at 9:29 AM
    shutterbug
    Cameron
    Downey, ID
    06 Blue Tacoma
    OK, maybe I'll just give a 52 tooth rear a try. Can I use the same chain or should I get a new one of those also? I'm gonna have a lot more questions for yall! I wanted a dirt bike since I was little but my dad was paranoid and said no dirt bike until I had my license, then I bought trucks and cars instead of a dirtbike
  15. Aug 20, 2013 at 9:30 AM
    BradyT88
    Yeah, I saw that on facebook and your build thread. haha
  16. Aug 20, 2013 at 9:49 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    damn. thats some fancy ass MIG. but may be TIG..
  17. Aug 20, 2013 at 10:06 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    brady...his 35s
    which he will need to be rid of anyway if he keeps his truck and puts the 37s under it
    depending on the tread of the 35s lol
    and yes, imma greedy vulture
  18. Aug 20, 2013 at 10:08 AM
    BradyT88
    I figured. Just thought I would give you crap:p
    Isn't he planning on DD'ing the 35's and wheeling the 37's though?
  19. Aug 20, 2013 at 10:09 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    better not :cool:
    once he sees how bad ass it looks on 37s he wont want to take them off
  20. Aug 20, 2013 at 10:12 AM
    BradyT88
    haha. But he is trying to keep it DD friendly:rolleyes: That's why he chose 4.56's over 4.88's:rolleyes:
