Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Aug 27, 2013 at 7:50 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    mah gerd. his truck has been beautiful since it's conception
  2. Aug 27, 2013 at 7:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I know. Only thing that it's missing is a front diff
  3. Aug 27, 2013 at 8:00 PM
    BradyT88
    BradyT88 Well-Known Member
    For what he does with it, that is not necessarily a bad thing. haha For the most part Prerunners can get more travel out of the same kit because they don't have to worry about the CV's binding. They can also run longer shocks because the shock body doesn't have to clear the CV's.
    Not sure about 1st gens, but 2nd gen non-LT Prerunners can fit 8" stroke C/O's while 4x4's can only clear 6" C/O's because the CV is in the way.
    I'll still keep my 4x4, but I live in Idaho and don't spend all my time in the whoops.
  4. Aug 27, 2013 at 8:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    He had pics and video of his rear setup someplace.........
  5. Aug 27, 2013 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea his is a 4+ over kit.
    And idk wtf your talking about. All LT kits use an 8" shock..stock is 6"
    I have seen the photos. Never a vid tho
  6. Aug 27, 2013 at 8:29 PM
    BradyT88
    Yeah, LT kits do. I meant non LT rigs and stock is like 4" or something. You can literally take a brand new 2nd gen Prerunner and stuff an 8" travel shock into it with very little work. It couldn't really use it until you got some after market UCA's, but after that it is pretty much MT up front. You can't do that with a 4x4 because the CV axle is in the way of the shock body.
  7. Aug 27, 2013 at 8:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Da faq you smoking man?
    Prerunners might fit a 8" but it's stupid even with a UCA caus the LCA wouldn't allow it to work..
    The only thing other then some travel numbers a prerunner has that I'd like is spindle lifts.
  8. Aug 27, 2013 at 8:39 PM
    BradyT88
    I never said I want a pre-runner, I was just saying that was one of the advantages. When I was looking into getting some coilovers for up front and measured everything out, If my CV wasn't in the way, I can fit some of the 8" travel King Coilovers with my current setup. I probably can't compress them all the way, but I can get pretty close to fully extending them. Might be somewhat pointless at first but you wouldn't have to buy a new set of C/O's when you go LT.
    If you find a set of 6" travel kings, you can add a 2" rod entension on the end and they will fit on 2nd gens and are basically the same extended length as 8's they just don't compress as much.
    Blackhawk88 has a write up on it on this site somewhere back before he went LT.
  9. Aug 27, 2013 at 8:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh I get what your saying. So an 8" shock doesn't have that long spindle like all other 2nd gen shocks do
    Loser haha :p I can fit an 8" 1st gen FTW
  10. Aug 27, 2013 at 8:47 PM
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    God damn dude. Yep well you fucked shut up this time for sure. ;)
  11. Aug 27, 2013 at 8:49 PM
    BradyT88
    Typically you see lots of short body 8" shocks on the 4wd LT rigs. Prerunners don't have to worry about it. I'll bet it is the same case for 1st gens as well. How else do you get around the CV axle unless your axles are just that skinny. Might explain why 1st gens break them easier. I guess it is also possible that your shock is far enough off to one side to clear the CV, but I think that would cause a weak point on the LCA pivot that is on the opposite side of the shock.
  12. Aug 27, 2013 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Only difference I know of on the shocks is the bottom coil bucket is flat for prerunners and a cone shape for us. Just shorter coils I think.
  13. Aug 28, 2013 at 7:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    man..Tuesdays are lame for me. I have class 9-1:30 and then 5:30-9:30. passed out early yesterday.
  14. Aug 28, 2013 at 7:47 AM
    BradyT88
    My tuesdays suck too... I ride with my wife to class so I get to campus at 7:30 so I work out until my 9:30 class that runs until 10:45 then I have lab at 11 that runs until 1:30 that rolls into work from 1-10... I was on campus for 14+ hours yesterday!:eek:
  15. Aug 28, 2013 at 8:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    looser haha
    nice!
    reminds me of mondays in highschool for me haha 14+ hours at highschool haha
  16. Aug 28, 2013 at 8:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Girls are over ratted.
  17. Aug 28, 2013 at 8:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, my tuesdays suck too. I get to work at 7 and have to stay til 4. :rolleyes:
    Wrong Hombre. Girls are soft and cuddly and can give much pleasure. :p
  18. Aug 28, 2013 at 8:53 AM
    BradyT88
    You get paid good money to to do that though. I paid to go for the 1st several hours of my Tuesday and then make just a hair over minimum wage for the rest of those hours. haha
    :rofl:
  19. Aug 28, 2013 at 8:55 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    3/4 elliptical or full eliptical will give LOADS of droop and LOADS of axle wrap without traction bars. By the time you do traction bars the right way to control the springs you might as well have 4-linked the thing.
    Not to mention they can be very sketchy on the road. Either setup should only be used on a trail only rig.
  20. Aug 28, 2013 at 8:57 AM
    BradyT88
    Yeah, every rig I have seen with it (all on the internet of course) have been trailer queens basically.
