Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 2, 2013 at 10:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    still something broken though..
  2. Sep 2, 2013 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When was the last time you checked the torque on the lower bj bolts on your truck?
  3. Sep 2, 2013 at 11:34 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    first thing I do in the morning will be to go out and tighten the fuck out of them
  4. Sep 2, 2013 at 11:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    don't over tighten them.
  5. Sep 3, 2013 at 12:34 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Just make sure they are not loose or one isn't missing. :eek:
    45 ft lbs is the torque spec I think. Which isn't all that much when you think about it. The wheel lugs are 90.
  6. Sep 3, 2013 at 11:18 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    i torque mine to 50 ft lbs. i always use blue thread lock and ive never had an issue. bent a drop braket and fucked up both passenger tierod ends ball joints are fine.
  7. Sep 3, 2013 at 11:53 AM
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    hassle to fix.... I would be the one fixing it ya jackass!!!!:D
    the only thing yould would have to worry about is finding clean underware.
  8. Sep 3, 2013 at 11:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    HA! true!
    but..not if you weren't on the trail if it happened there...:p
    then it would be me...
    okay..
    Mark..don't break shit haha
  9. Sep 3, 2013 at 12:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    im ordering a lca bj set to swap mine out winter break
    too afraid to break something else. haha
  10. Sep 3, 2013 at 12:02 PM
    BradyT88
    BradyT88 Well-Known Member
  11. Sep 3, 2013 at 12:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why? are yours blown? if they aren't and have almost no play..leave them alone.
  12. Sep 3, 2013 at 12:03 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    well
    they're squirting grease
    is that bad? :cookiemonster:
    Good thing I swapped my UCA's too, found one of my bj's were worn as shit, don't wanna take the chance with the lowers
  13. Sep 3, 2013 at 12:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah okay.
    all mine are...bad...real bad..:eek:
    Was hoping for LT..
  14. Sep 3, 2013 at 12:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I didn't check for play yet though...kinda scared
    but i noticed the grease during the mt install... didnt want to deal with it then
    you do have the glass already....it's only money, monte!!
  15. Sep 3, 2013 at 12:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im trying!!
    also just a bit a grease is fine..hell..mine have been done for much longer then i am proud to say..
  16. Sep 3, 2013 at 12:32 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    i dont like that if they fail...the wheel falls off. lol
    but i didn't know how easy they were to swap
    what's your plan for lt?
  17. Sep 3, 2013 at 12:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well..the wheel doesn't REALLY..fall off..sorta..ish..haha
    just go slow :p haha
    LT wise..idk..MCM has a good lookin kit for a great price..but i wouldn't mind a TC kit really..there is a BTF fab 4.5'' over half finished kit(needs mounts welded for shocks/straps) on TTORA that would be sweet to make work with custom axles and maybe some 10'' ORIs for epic travel..but..due to money..MCM looks killer haha plus supposed to come with shocks and coils for that price.
    Then still want the Cantilever Engage kit for the rear
    But..thats a shit load of money i don't have..and i need to replace all 4 shocks very soon. fronts are getting wore out(mostly coils, might as well do the whole coil over) and rears i be have no oil hardly left in them.
    Makes for a nice soft ride all the time..but..sometimes too soft and allows too much body roll.
    No really sure wtf is next really. I mean..obviously getting the 35s mounted and the gears installed is next..but after that..no idea.
  18. Sep 3, 2013 at 12:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Id go with a canti setup if there was a good offroad fab shop here....
    mcm made a canti kit too
    mike said he had to get bigger bumps and shorter straps for his canti's because he was getting too much travel :eek:
  19. Sep 3, 2013 at 12:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah man. I have a TON of weight up there.
    Huge skid, Plate bumper, dual batteries, winch. I honestly think its the coils.
    Mostly cause i was sitting lower then when i started after the trip..particularly after Lander haha
  20. Sep 3, 2013 at 12:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    MCM makes a canti kit? or a custom kit?
    Cause you can just order the Engage kit as either a full DIY, a weld together kit, or mostly bolt on with some welding(frame stuff).
    Was gonna go with the weld kit.
    But in MCM makes one..that could be interesting..
